I’m in the process to install a new server to replace an old one. I have done the whole virtualmin setup and wizard. Then I have imported through backup/restore virtualmin configuration from old server to new one.
Now when I do a server check it tells me server has a public IP different of the one reported in config file (public ip reported is the one of the old server !).
The status of your system is being checked to ensure that all enabled features are available and properly configured …
Your system has 62.68 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB
BIND DNS server is installed
Mail server Postfix is installed and configured
Postfix is configured to support per-domain outgoing IP addresses
Apache is installed
Apache does not support HTTP/2 : Incompatible Apache mpm_prefork module is enabled
The following CGI script execution modes are available : suexec fcgiwrap
The following PHP execution modes are available : fpm fcgid cgi
The following PHP versions are available : 7.3.33 (/bin/php7.3), 7.4.33 (/bin/php7.4), 8.2.25 (/bin/php-cgi8.2), 8.3.13 (/bin/php-cgi8.3)
The following PHP-FPM versions are available : 7.3.33 (php7.3-fpm) 7.4.33 (php7.4-fpm) 8.2.25 (php8.2-fpm) 8.3.13 (php8.3-fpm)
Webalizer is installed
Apache is configured to host SSL websites
MariaDB 10.11.6 is installed and running
PostgreSQL 15.8 is installed and running
ProFTPD is installed
Logrotate is installed
SpamAssassin and Procmail are installed and configured for use
ClamAV is installed and assumed to be running
The System and Server Status module is installed and checking on schedule
Plugin AWStats reporting is installed
Plugin Protected web directories is installed
Using network interface enp3s0f0 for virtual IPs
IPv6 addresses are available, using interface enp3s0f0
Default IPv4 address for virtual servers is 185.74.68.252
Default IPv6 address for virtual servers is 2001:X:X:X:ec4:7aff:fe6e:f698
External IP address for DNS records is set to ipaddressofnewserver, but the detected external address is actually ipaddressofoldserver. This may cause DNS records for Virtualmin domains to point to the wrong system
Both user and group quotas are enabled for home and email directories
All commands needed to create and restore backups are installed
Resource limits are supported and configured correctly
The selected package management and update systems are installed
Chroot jails are available
The Virtualmin APT repository is configured correctly
.. your system is ready for use by Virtualmin
OS type and version
Debian 12 x86_64
Webmin version
2.202
Virtualmin version
7.20.2 Pro
Webserver version
Apache 2.4.62
I have checked all configuration files but nothing indicates ip address of old server. Any idea why it’s doing that ?
has the new ip propagated - it takes time for the new ip to be propagated round the globe sometimes as long as 48hr) use a dnscheck service to see if is pointing to the correct place.
not a problem of progagation as both old and new server have their own public IP configured in DNS since months and propagation is only for DNS entries not for IPs
Problem looks to have appeared since I imported a backup of Virtualmin configuration from old server in new server. Only problem I can’t find out where that old IP address is saved in config as everywhere I checked on new server has well the proper ip of the new server…
I noticed also that if I go in the Dynamic IP update (not used in my case), it lists in Primary Interface IP address the proper IPv4 of server but in Externally visible IP Address it reports IP of the old server !
I don’t understand how is that possible ? as for me the externally visible IP address is obtained by querying an external server on internet so it’s impossible that it reports the address of the old server (that is in a different DC !).
Sorry but problem is not with virtual servers (I have none setup yet on that new server), it’s the server itself that Virtualmin doesn’t handle properly !
Have you actually checked your NICs to see what IP is defined there? Webmin --> Networking --> Network Interfaces
Then I have imported through backup/restore virtualmin configuration from old server to new one. = This should not change the servers IP, the webmin config import/export probably will.
thanks for the basic question I know my IPs all the more when the problem concerns some IPs of 2 different DC !
it should not too as it’s part of local parameters I would say Even if it was doing, once done a recheck of virtualmin config it should automatically correct the issue !
What puzzles me here is that check of public IP of server is done I suspect by contacting a server on Internet so how can it get the old IP on a machine that is on a totally different network ??
We don’t cache on the server side, but maybe the query on the Virtualmin side got accidentally included in status caching. That’d be a problem. Really, I’m surprised Re-check configuration would ever get any cached data, though…that’s the point of checking.
@Ilia are we pulling anything from cached data in Re-Check Configuration? That’d be a bug.
@Ilia Thanks a lot for the so fast patch applied but not sure how to test it. Should I try again the reimport of Virtualmin settings from old server ? and then do a Configuration check on new server ?
Side note: an other bug sorry for that Now the new server and old server displays a warning about licence being used on 3 systems !!! The licence is only used on the old server and the new server that is going to replace it.
**A problem was detected with your Virtualmin license :**
Your serial number XXXXXX is licensed for only 1 server, but is being used on 3. Unless this serial number is used temporarily in order to migrate to a new server, please purchase an additional license at [Virtualmin Shop](https://virtualmin.com/shop/).
yeah but why does it state 3 systems sharing same licence while there are only two of them ? or it gets messed up because one of the server has both IPv4 and 6 active on it ?
oki so then why does it report licence used on 3 hosts ? while there is only 2 Is there a way to see IPs of servers system sees attached at that licence ?
