Help with ssl and configure it
ok thank you i will do that
Goodnight :slight_smile:
Yep, no idea on that router. Manual should show it, else google it.
its afternoon here in scotland lol
ok thanks you
DMZing on the router is the easiest method enable you server to be assess from the internet.
this may help
destination host being Virtualmin server
ok thank you for your help very much appreciated
I can’t access your website, you may need to reboot the router.
For security reason try blank out your IPs.
Your ISP has given you a Fix IP (the one the dns points too)?
thats everything from the suggested dns records
ok im just about to reboot my router now
thats my router rebooted now
I still not getting mail working on mxtoolbox. The hostname I can’t see the full address, make sure it hasn’t added extra stuff at end.
how do i do that please
what expected has happen, when you add the record either just use mail or mail.castlivenow.com.
there needs to be a dot at the end else it will do what is in the screenshot
google whatmyip and confirm you are still using that IP. I suspect you don’t have a fixed IP.
ok will do that now
its saying that my ipaddres is what im using
Screenshot_3
Screenshot_4
when i go to the preview website it comes up
like this
something blocking, maybe your ISP
