Help with ssl and configure it
i just want the easy way possiable
Lets Encrypt then, so easy :slight_smile:
ok thanks for your help
now im having problem with lets encrypt its saying this error
Looks like you dns is not setup correctly.
is this your IP
yes thats my ip address
ok, not sure that failed but www has no IP. Meaning you have no A or CNAME for it.
im also using the namecheap dns server to i can take a screenshot of that if you like
I can’t connect to your website, you may have a firewall issue. Where is your Virtualmin hosted? On your own or a VPS?
thats my name cheap dns server that im using
You need to copy the suggest DNS records to namecheap and access to the server, at the moment I see none.
ok thanks for your help and how do i solve the firewall issue too
where is the server being run? Your home or hosted somewhere? Virtualmin itself has the correct ports open. You must behind a firewall, maybe a router.
on my own server at home
i dont have that on my virtualmin pro
You need to either do portforwarding or make it a DMZ in the router. Look up you routers manual on how to do that.
ok thank you
the routre im using is the asus RT-AC85P
disable dns on the virtualserver, if you using namecheap for dns it is not needed. suggested dns is then visible.
