Help with ssl and configure it
oh right so how do i solve that then
yeah that just a way Virtualmin to show your website, its using your local address, check the url
i know i havent setup a web page yet as im trying to get the rest of it setup firist
Is there any other router? Like your isp’s router.
yes the main sky hub its self
That IP maybe that hub do you have access, your router may have a local ip.
im just looking now
maybe you need to specify a address, yeah reading it seems so
yes i do im just doing that now
bingo
but website still timing out, ping is now timeing out, now working
oh what could be the problem there
this is what is showing up my end
not sure, is the server pluged into hub or router.
its plugged into the router
you dmz the router
yes i think i have
its pinging something :slight_smile:
Ok, just thinking, is the virtualmin server detecting the IP?
thats the ip address that is show up
this is what shows up on my dashbroad
