Website IP4 is differnt than IP6
I am getting an error from https://internet.nl/site/yr-design.biz/3126992/#control-panel-4 with the message:
" Available ports or offered headers of your website over IPv4 are not the same over IPv6."
As far as know, my virtualmin setup was working fine before. I have checked many things, but I can not find out how to change the setup. Anyone can give me a suggestion where to look.
Warm regards
Rob Oudendijk
Which web server do you use, Nginx or Apache?
Virtualmin has a firewall and it was likely configured correctly when you installed Virtualmin; your service provider also offers a firewall. Is this firewall configured symmetrically for IPv4 and IPv6?
Calport,
Thank you for the reply.
I use Apache server. I am not sure how to check the firewall.
You have a suggestion?
Regards
Rob Oudendijk.
It seems your website is available via IPv4 only:
curl -4 -I http://yr-design.biz # throws header
curl -4 -I https://yr-design.biz # throws header
curl -6 -I http://yr-design.biz # fails to connect
curl -6 -I https://yr-design.biz # fails to connect
Check your Apache config to have consistent configuration for both IPv4 and IPv6. Look for the Listen and VirtualHost directives. Make sure the IPv4 (Listen 80) and IPv6 (Listen [::]:80) directives are both present for the same ports:
<VirtualHost *:80>
ServerName yr-design.biz
</VirtualHost>
<VirtualHost [::]:80>
</VirtualHost>
<VirtualHost *:443>
</VirtualHost>
<VirtualHost [::]:443>
</VirtualHost>
Steini,
Thank you for checking out the issue.
As far as I can see on virtualmin is fine:
<VirtualHost 80.208.225.44:443 [2a02:7b40:50d0:e12c::1]:443>
No firewalls rules are set up.
Sorry for ignorance. I am not an expert.
Could it be my VPS not having and Ip6 anymore?
Or Cloudflare is not letting IP6 traffic through?
Regards,
Rob Oudendijk
Verify your DNS records for NS and AAAA entries. Is the IPv6 there?
SteinI,
I did some checking. When I run the curl command for IP4 and IP6 inside the VPS, all works fine:
root@yr-design:~# curl -6 -I http://yr-design.biz
HTTP/1.1 302 Found
Date: Sun, 26 Jan 2025 13:19:19 GMT
Server: Apache
Content-Type: text/html; charset=iso-8859-1
root@yr-design:~# curl -4 -I http://yr-design.biz
HTTP/1.1 302 Found
Date: Sun, 26 Jan 2025 13:19:35 GMT
Server: Apache
root@yr-design:~#
Maybe by VPS is not accesable by IP6?
Regards
Rob Oudendijk
no https on your ipv4.
80.208.225.44
ipv6 seems fine, responds to ping and https.
SteinI,
Maybe some routing wrong?
regards
Rob
Regards
Rob
Course there is.
Hit your terminal:
ip addr
Can you confirm your IPv4 and IPv6 addresses are listed?
Steini,
root@yr-design:~# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:00:50:d0:e1:2c brd ff:ff:ff:ff:ff:ff
inet 80.208.225.44/32 scope global ens3
inet 10.208.225.44/8 brd 10.255.255.255 scope global ens3
inet6 2a02:7b40:50d0:e12c::1/128 scope global
inet6 fe80::200:50ff:fed0:e12c/64 scope link
root@yr-design:~#
in Virtualmin go to “Manage Virtual Server” then “change IP Address”
and then verify ports and IP. (better to have it shared)
dont know that that 10.208.225.44 is?
FYI… All my other website have same issue on that VPS…
Maybe my Ubuntu setup?
So, what did you do before then and now that could have triggered the issue?
Have a look if your domains, ports, and IPs are properly listed:
apachectl -S
VirtualHost configuration:
[2a02:7b40:50d0:e12c::1]:80 is a NameVirtualHost
default server yr-design.biz (/etc/apache2/sites-enabled/0-yr-design.biz.conf:1)
         port 80 namevhost yr-design.biz (/etc/apache2/sites-enabled/0-yr-design.biz.conf:1)
                 alias www.yr-design.biz
                 alias mail.yr-design.biz
                 alias webmail.yr-design.biz
                 alias admin.yr-design.biz
                 alias autoconfig.yr-design.biz
                 alias autodiscover.yr-design.biz
         port 80 namevhost azbybrown.com (/etc/apache2/sites-enabled/azbybrown.com.conf:1)
                 alias www.azbybrown.com
                 alias mail.azbybrown.com
                 alias webmail.azbybrown.com
                 alias admin.azbybrown.com
                 alias autoconfig.azbybrown.com
                 alias autodiscover.azbybrown.com
         port 80 namevhost bestillandknow.info (/etc/apache2/sites-enabled/bestillandknow.info.conf:1)
                 alias www.bestillandknow.info
                 alias mail.bestillandknow.info
                 alias webmail.bestillandknow.info
                 alias admin.bestillandknow.info
                 alias autoconfig.bestillandknow.info
                 alias autodiscover.bestillandknow.info
         port 80 namevhost bgeigiezen.safecast.jp (/etc/apache2/sites-enabled/bgeigiezen.safecast.jp.conf:1)
                 alias www.bgeigiezen.safecast.jp
                 alias mail.bgeigiezen.safecast.jp
                 alias webmail.bgeigiezen.safecast.jp
                 alias admin.bgeigiezen.safecast.jp
                 alias autoconfig.bgeigiezen.safecast.jp
                 alias autodiscover.bgeigiezen.safecast.jp
         port 80 namevhost catherinestine.com (/etc/apache2/sites-enabled/catherinestine.com.conf:1)
                 alias www.catherinestine.com
                 alias mail.catherinestine.com
                 alias webmail.catherinestine.com
                 alias admin.catherinestine.com
                 alias autoconfig.catherinestine.com
                 alias autodiscover.catherinestine.com
         port 80 namevhost jesusprayertv.com (/etc/apache2/sites-enabled/jesusprayertv.com.conf:1)
                 alias www.jesusprayertv.com
                 alias mail.jesusprayertv.com
                 alias webmail.jesusprayertv.com
                 alias admin.jesusprayertv.com
                 alias autoconfig.jesusprayertv.com
                 alias autodiscover.jesusprayertv.com
         port 80 namevhost legalvideoasia.com (/etc/apache2/sites-enabled/legalvideoasia.com.conf:1)
                 alias www.legalvideoasia.com
                 alias mail.legalvideoasia.com
                 alias webmail.legalvideoasia.com
                 alias admin.legalvideoasia.com
                 alias autoconfig.legalvideoasia.com
                 alias autodiscover.legalvideoasia.com
         port 80 namevhost magneticarts.com (/etc/apache2/sites-enabled/magneticarts.com.conf:1)
                 alias www.magneticarts.com
                 alias mail.magneticarts.com
                 alias webmail.magneticarts.com
                 alias admin.magneticarts.com
                 alias autoconfig.magneticarts.com
                 alias autodiscover.magneticarts.com
         port 80 namevhost new.yr-design.biz (/etc/apache2/sites-enabled/new.yr-design.biz.conf:1)
                 alias www.new.yr-design.biz
                 alias mail.new.yr-design.biz
                 alias webmail.new.yr-design.biz
                 alias admin.new.yr-design.biz
                 alias autoconfig.new.yr-design.biz
                 alias autodiscover.new.yr-design.biz
         port 80 namevhost norrischumley.com (/etc/apache2/sites-enabled/norrischumley.com.conf:1)
                 alias www.norrischumley.com
                 alias mail.norrischumley.com
                 alias webmail.norrischumley.com
                 alias admin.norrischumley.com
                 alias autoconfig.norrischumley.com
                 alias autodiscover.norrischumley.com
         port 80 namevhost oudendijk.biz (/etc/apache2/sites-enabled/oudendijk.biz.conf:1)
                 alias www.oudendijk.biz
                 alias mail.oudendijk.biz
                 alias webmail.oudendijk.biz
                 alias admin.oudendijk.biz
                 alias autoconfig.oudendijk.biz
                 alias autodiscover.oudendijk.biz
         port 80 namevhost rawfood-services.com (/etc/apache2/sites-enabled/rawfood-services.com.conf:1)
                 alias www.rawfood-services.com
                 alias mail.rawfood-services.com
                 alias webmail.rawfood-services.com
                 alias admin.rawfood-services.com
                 alias autoconfig.rawfood-services.com
                 alias autodiscover.rawfood-services.com
         port 80 namevhost roboudendijk.com (/etc/apache2/sites-enabled/roboudendijk.com.conf:1)
                 alias www.roboudendijk.com
                 alias mail.roboudendijk.com
                 alias webmail.roboudendijk.com
                 alias admin.roboudendijk.com
                 alias autoconfig.roboudendijk.com
                 alias autodiscover.roboudendijk.com
         port 80 namevhost shop.safecast.jp (/etc/apache2/sites-enabled/shop.safecast.jp.conf:1)
                 alias www.shop.safecast.jp
                 alias mail.shop.safecast.jp
                 alias webmail.shop.safecast.jp
                 alias admin.shop.safecast.jp
                 alias autoconfig.shop.safecast.jp
                 alias autodiscover.shop.safecast.jp
         port 80 namevhost spinfish.tv (/etc/apache2/sites-enabled/spinfish.tv.conf:1)
                 alias www.spinfish.tv
                 alias mail.spinfish.tv
                 alias webmail.spinfish.tv
                 alias admin.spinfish.tv
                 alias autoconfig.spinfish.tv
                 alias autodiscover.spinfish.tv
[2a02:7b40:50d0:e12c::1]:443 is a NameVirtualHost
         default server yr-design.biz (/etc/apache2/sites-enabled/0-yr-design.biz.conf:85)
         port 443 namevhost yr-design.biz (/etc/apache2/sites-enabled/0-yr-design.biz.conf:85)
         port 443 namevhost azbybrown.com (/etc/apache2/sites-enabled/azbybrown.com.conf:82)
         port 443 namevhost bestillandknow.info (/etc/apache2/sites-enabled/bestillandknow.info.conf:82)
         port 443 namevhost bgeigiezen.safecast.jp (/etc/apache2/sites-enabled/bgeigiezen.safecast.jp.conf:82)
         port 443 namevhost catherinestine.com (/etc/apache2/sites-enabled/catherinestine.com.conf:70)
         port 443 namevhost jesusprayertv.com (/etc/apache2/sites-enabled/jesusprayertv.com.conf:48)
         port 443 namevhost legalvideoasia.com (/etc/apache2/sites-enabled/legalvideoasia.com.conf:82)
         port 443 namevhost magneticarts.com (/etc/apache2/sites-enabled/magneticarts.com.conf:82)
         port 443 namevhost new.yr-design.biz (/etc/apache2/sites-enabled/new.yr-design.biz.conf:59)
         port 443 namevhost norrischumley.com (/etc/apache2/sites-enabled/norrischumley.com.conf:89)
         port 443 namevhost oudendijk.biz (/etc/apache2/sites-enabled/oudendijk.biz.conf:82)
         port 443 namevhost rawfood-services.com (/etc/apache2/sites-enabled/rawfood-services.com.conf:82)
         port 443 namevhost roboudendijk.com (/etc/apache2/sites-enabled/roboudendijk.com.conf:54)
         port 443 namevhost shop.safecast.jp (/etc/apache2/sites-enabled/shop.safecast.jp.conf:90)
         port 443 namevhost spinfish.tv (/etc/apache2/sites-enabled/spinfish.tv.conf:82)
80.208.225.44:80       is a NameVirtualHost
         port 80 namevhost hagenberg.com (/etc/apache2/sites-enabled/hagenberg.com.conf:1)
                 alias www.hagenberg.com
                 alias mail.hagenberg.com
                 alias webmail.hagenberg.com
                 alias admin.hagenberg.com
                 alias autoconfig.hagenberg.com
                 alias autodiscover.hagenberg.com
         port 80 namevhost kittywood.work (/etc/apache2/sites-enabled/kittywood.work.conf:1)
                 alias www.kittywood.work
                 alias mail.kittywood.work
                 alias webmail.kittywood.work
                 alias admin.kittywood.work
                 alias autoconfig.kittywood.work
                 alias autodiscover.kittywood.work
80.208.225.44:443      is a NameVirtualHost
         port 443 namevhost hagenberg.com (/etc/apache2/sites-enabled/hagenberg.com.conf:67)
         port 443 namevhost kittywood.work (/etc/apache2/sites-enabled/kittywood.work.conf:68)
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www/html"
Main ErrorLog: "/var/log/apache2/error.log"
Mutex mpm-accept: using_defaults
Mutex fcgid-pipe: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex watchdog-callback: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex rewrite-map: using_defaults
Mutex ssl-stapling-refresh: using_defaults
Mutex authdigest-client: using_defaults
Mutex fcgid-proctbl: using_defaults
Mutex ssl-stapling: using_defaults
Mutex proxy: using_defaults
Mutex ssl-cache: using_defaults
Mutex default: dir="/var/run/apache2/" mechanism=default
PidFile: "/var/run/apache2/apache2.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: ENABLE_USR_LIB_CGI_BIN
User: name="www-data" id=33
Group: name="www-data" id=33
root@yr-design:~# ```
SteinI.
I do not see websites on the IP6?
Regards
Rob
It’s all there. I’m running out of decent advice… If you paste code or config lines, please wrap them in backticks (three at the start, three at the end). Makes it easier to read.
Steini,
Thank you for all the advice.
Sorry for the long lines. I fixed it.
Regards,
Rob Oudendijk
