| SYSTEM INFORMATION | |
| OS type and version | CENTOS7 |
| Webmin version | 1.993 |
| Virtualmin version | 7.1 Pro |
| Related packages | SUGGESTED |
uninstalling
Removing nameserver 127.0.0.1 from /etc/resolv.conf
Removing virtualmin repo configuration
Removing virtualmin-release [
Removing /etc/virtualmin-license, if it exists.
Done. There’s probably quite a bit of related packages and such left behind
but all of the Virtualmin-specific packages have been removed.
[root@server ~]# server webmin restart
-bash: server: command not found
[root@server ~]# sudo /etc/init.d/webmin restart
sudo: /etc/init.d/webmin: command not found
[root@server ~]# sudo /etc/webmin/restart
sudo: /etc/webmin/restart: command not found
[root@server ~]# systemctl restart webmin.service
Failed to restart webmin.service: Unit not found.
[root@server ~]# service webmin start
Redirecting to /bin/systemctl start webmin.service
Failed to start webmin.service: Unit not found.
[root@server ~]# service webmin status
Redirecting to /bin/systemctl status webmin.service
● webmin.service
Loaded: not-found (Reason: No such file or directory)
Active: failed (Result: exit-code) since Sat 2022-06-04 18:20:26 UTC; 7min ago
Main PID: 22545 (code=exited, status=1/FAILURE)
Jun 03 16:18:50 server.mydomain.com systemd[1]: Starting Webmin server daemon…
Jun 03 16:18:50 server.mydomain.com .start-init[22544]: Starting Webmin server in /usr/libexec/webmin
Jun 03 16:18:50 server.mydomain.com webmin[22544]: Webmin starting
Jun 03 16:18:50 server.mydomain.com systemd[1]: Can’t open PID file /var/webmin/miniserv.pid (yet?) after st…tory
Jun 03 16:18:50 server.mydomain.com systemd[1]: Started Webmin server daemon.
Jun 04 18:20:26 server.mydomain.com systemd[1]: Stopping webmin.service…
Jun 04 18:20:26 server.mydomain.com systemd[1]: webmin.service: main process exited, code=exited, status=1/FAILURE
Jun 04 18:20:26 server.mydomain.com systemd[1]: Stopped webmin.service.
Jun 04 18:20:26 server.mydomain.com systemd[1]: Unit webmin.service entered failed state.
Jun 04 18:20:26 server.mydomain.com systemd[1]: webmin.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
[root@server ~]# systemctl start webmin.service
