Webmin Fatal ProFTP
@Ilia thanks - it really did not like that, seemed to go ok then shut everything down,
after reboot i logged back in ok.
the error message has gone :+1:
but it has not got rid of the problem.
the VM still thinks “ProFTPD FTP Server” is there (it is listed in “Servers Status” as not running and refuses to start)
access denied: user root is not allowed to use ProFTPd Server module
which is crazy access by root denied ! :grimacing:
SUCCESS!
despite the previous outcome at least the checkbox untick worked.
then i could remove proftp from “features and plugins”
and delete from “bootup and shutdown”
a final reboot
and good to go again just in time for tomorrow’s backup
thanks once again for everyone’s help :grinning_face:
Glad you got it fixed, but I would have just disabled the proftpd service(s) tather than deleting them, another customer on the same VM may ask for it
if they do i can advise them “not to be
” now i have a copy of that warning help on file and have experience of the trauma it creates.
the only person likely to ask will be new and have a good reason to justify it and i could always set up a new environment specifically for them.
but thanks anyway.
