at webmin.com, it says that VirtualMin v7 has been released. But on the VM forums it states that is false.
who can update webmin.com to fix this ??
Edit: yeah, what @jotst said.
either the terminalogy has changed, or I just donât âget itâ ⊠at webmin.com if I scroll down just a bit, I come to
Virtualmin 6.17 released
which matches exactly the Sept 9 2021 changelog entry for 6.17
also when I look on my RedHat system for RPM packages, I find this
[root@vhost90 ~]# yum list wbm-virtual-server
Installed Packages
wbm-virtual-server.noarch 3:6.17.gpl-3 @virtualmin-universal
which makes me think, from the 6.17 version ID, that wbm-virtual-server.noarch aka virtual-server IS the actual virtualmin package.
and at
v6.17 is followed by 7.0
what am I missing here?
If you are running Virtualmin, you should NOT be relying on information at webmin.com.
While Virtualmin is a module built on top of Webmin, you should be tracking and utilizing information found at virtualmin.com as the webmin.com website is primarily focused on âwebmin-onlyâ installs rather then the Virtualmin platform.
This also goes for those who seem to be adding the âwebminâ repos to their installation then getting a reality check when webmin stops working as itâs out of sync with the version distributed on virtualmin.com (which is vetted, and includes additional adjustments / fixes before being released)
Virtualmin is a set of packages and an installer. It is not just one Webmin module.
