Virtualmin Pro for Bullseye Debian 11
I would like to know when Virtualmin Pro would be available for Debian 11. I need to setup a new server with Virtualmin Pro. However it seems that the pro repository isn´t available yet.
Does anybody know when it will be possible to upgrade to Pro version? We actually need to do the setup of the new server soon.
Thomas
Hit:1 Index of /debian bullseye InRelease
Get:2 Index of /debian bullseye-updates InRelease [39.4 kB]
Hit:3 Index of /debian-security bullseye-security InRelease
Ign:4 https://software.virtualmin.com/vm/7/apt virtualmin InRelease
Err:5 https://software.virtualmin.com/vm/7/apt virtualmin Release
404 Not Found [IP: xxxxxxx]
Reading package lists…
E: The repository ‘https://software.virtualmin.com/vm/7/apt virtualmin Release’ does not have a Release file.
OS type and version Debian 11
Webmin version 1.994
Virtualmin version 7.1-1
It’s in Beta right now.
Meaning what in time?
You are welcome to take some insignificant risk and install it using development version of install.sh script, which should work just fine. Before installing, and after downloading linked install.sh script, replace SERIAL and KEY with those purchased ones, which can be found in virtualmin.com → My Account → Software Licenses page.
I have version 6 of virtualmin installed, but I would need the debian 11 repos, it would be this script, install.sh for sure on a production server with debian 11 and virtualmin 6 already installed
Hi, if this problem still exists, I have a solution found.
Change the uri in the entry within /etc/apt/sources.list.d/virtualmin.list.
In my case is the entry then
deb [signed-by=/usr/share/keyrings/debian-virtualmin-7.gpg] https://software.virtualmin.com/vm/7/pro/apt virtualmin main
Then upgrade to pro as within Software Licenses FAQ – Virtualmin described.
It would be better to use devel version of VIrtualmin 7 install.sh script with Debian 11, rather than changing repos manually.
OK, but if the installation with the gpl script is already been executed is the changing of the apt source faster, or not?
What ist so better on the use of the development script?
If it was already installed, you could use mentioned pre-release (devel) version of the virtualmin-install.sh script and run it with --setup param to setup repos and exit. You may need to edit the script manually and put your actual SERIAL and KEY in it. Afterwards running apt-get upgrade should install Virtualmin Pro on your system.
Currently there is a bug in Virtualmin GPL that will prevent upgrades from GPL to Pro version using UI. It will be fixed in the next Virtualmin release.
