Virtualmin Podman module 1.6.0 initial release
After months of development and testing, the Virtualmin Podman plugin is now production-ready and available to all Virtualmin Pro users through the standard repositories.
The plugin brings per-domain container and pod management to Virtualmin. You can create and manage standalone containers or multi-container pods, configure networking and storage, publish services through Virtualmin’s reverse proxy, inspect logs, and open container terminals directly in the browser.
It also includes a growing catalog of Application Recipes for deploying complete applications, including their databases, storage, generated secrets, networking, and reverse proxy configuration, with just a few clicks.
You can find Manage Container Apps within each enabled virtual server and Container Apps Manager in the main navigation for cross-domain administration.
The UI, command-line interface, and authenticated remote API all support container, pod, and Application Recipe management.
Currently Virtualmin Podman 1.6.0 includes the following 102 ready-to-deploy application recipes:
  • Actual Budget
  • Adminer
  • Apache Tomcat
  • Audiobookshelf
  • BookOrbit
  • BookStack
  • Caddy Static Site
  • Calibre-Web
  • ChangeDetection.io
  • Chatwoot
  • Code Server
  • Collabora Online
  • Directus
  • Discourse
  • Django
  • Docmost
  • Dolibarr
  • Draw.io
  • ejabberd
  • EspoCRM
  • Etherpad
  • Excalidraw
  • FastAPI
  • Firefly III
  • Flask
  • FrankenPHP
  • FreeScout
  • FreshRSS
  • Ghost
  • Gitea
  • GLPI
  • Go
  • Gotify
  • Grafana
  • Grafana OpenTelemetry LGTM
  • Grocy
  • HedgeDoc
  • Homebox
  • Homer
  • Immich
  • InfluxDB
  • Invoice Ninja
  • IT-Tools
  • Jellyfin
  • Joplin Server
  • Kanboard
  • Karakeep
  • Kavita
  • Keycloak
  • Kimai
  • Leantime
  • linkding
  • Listmonk
  • Mailpit
  • Matomo
  • Mattermost
  • Mautic
  • Mealie
  • Memos
  • Metabase
  • Miniflux
  • MongoDB with mongo-express
  • n8n
  • Navidrome
  • Nextcloud
  • NGINX Static Site
  • NocoDB
  • Node-RED
  • Node.js
  • ntfy
  • Odoo Community
  • Open WebUI
  • OpenSearch
  • PairDrop
  • Paperless-ngx
  • Penpot
  • pgAdmin
  • PhotoPrism
  • phpMyAdmin
  • PLANKA
  • Pocket ID
  • PrestaShop
  • PrivateBin
  • Prometheus
  • RabbitMQ
  • Redmine
  • Ruby
  • SearXNG
  • SFTPGo
  • Snipe-IT
  • Stirling PDF
  • Tandoor Recipes
  • Trilium Notes
  • Twenty CRM
  • Umami
  • Uptime Kuma
  • Vaultwarden
  • Vikunja
  • Wallos
  • Wiki.js
  • WordPress
  • YOURLS
Screenshots
README.md
Virtualmin Podman Plugin
Virtualmin Podman plugin for deploying and managing Podman containers and pods
per virtual server, with integrated networking, proxying, runtime controls,
logs, and browser terminal access.
Overview
This module adds Podman management for virtual servers. It supports both
container and pod workflows, runtime-aware rootless and rootful execution,
reverse proxy integration, image discovery, reusable defaults, and
browser-based troubleshooting tools.
Current features
Application recipes
  • Guided deployment of complete applications from the domain container page
  • Automatic pods, private database/cache containers, generated secrets,
    persistent storage, and published ports, with either domain-root reverse
    proxying or an explicitly declared host-only loopback endpoint
  • Long-running worker and scheduler components, with optional deferred startup
    after one-time application initialization
  • Selectable initial administrator credentials for applications whose images
    support unattended account creation
  • Root-only retention and installed-recipe display of those initial login
    credentials for later recovery
  • Preflight checks for compatible runtime mode, domain quota, free disk space,
    and available memory where applications declare minimum requirements
  • Transactional rollback of containers, pods, proxy configuration, and newly
    created storage when a deployment fails
  • Normal container and pod editing, lifecycle, logs, cloning, and deletion
    after deployment
  • One strict JSON definition per built-in recipe in the module’s recipes/
    directory
  • Trusted local recipe additions and overrides from
    /etc/webmin/virtualmin-podman/recipes/; each filename must match its recipe
    ID, and a local definition with an existing ID replaces the built-in recipe
Recipe components can use the application, database, cache, service,
worker, or scheduler role. A worker or scheduler with
"start_after_initialize": 1 is created only after the application endpoint is
reachable and every earlier component has completed its optional one-time
initialize command. Deferred components must be placed last in the variant.
They remain ordinary managed containers, so pod and container lifecycle, logs,
editing, and rollback work without a separate host cron or systemd service.
A dependency component with "initialize_before_dependents": 1 completes its
declared initialize command immediately after its own readiness check and
before the next component is created. This supports services that must rotate
bootstrap credentials or finish other one-time setup before their application
consumer starts.
Recipe variants may set "exposure": "loopback" to bind published ports only
to 127.0.0.1; omitted exposure retains the compatible public-web behavior.
When one recipe offers both modes, its install form shows the access choice.
Loopback variants may override app_port and declare connection_scheme or
connection_path for the connection details shown after deployment. The
published port selected as a reverse-proxy target is automatically bound to
127.0.0.1; additional service ports retain their declared public exposure.
Multi-variant recipes that select an application stack may set
"variant_type": "stack" to label that choice as an application stack instead
of a database. Each variant may provide an optional plain-text description;
the install form shows the selected variant’s description beneath the selector.
A multi-container recipe whose public application component is only a proxy
can mark its actual application component with "version_source": 1.
Installed-recipe version reporting then uses that component’s image metadata
instead of the proxy image.
Containers
  • Domain-scoped management view for each virtual server
  • Global cross-domain container listing
  • Fast metadata-only global status views with an explicit runtime refresh action
  • Install, edit, save/reinstall, start, stop, restart, delete, and bulk
    lifecycle actions
  • Configurable list columns for ports, paths, volumes, envs, status, logs,
    console access, and optional runtime usage stats
  • Quick links to logs and terminal console from list and details views
  • Runtime metadata and inspect summaries for troubleshooting
Compose import
  • Advanced one-time import from an uploaded Docker Compose YAML file and
    optional project .env
  • Preview of normalized services, images, published ports, bind mounts, named
    volumes, networks, and dependency order before deployment
  • Adoption of matching existing, unmanaged Podman Compose services without
    restarting them
  • Reuse of existing named volumes and networks so persistent data remains in
    place
  • Fail-closed validation for unsupported Compose behavior instead of silently
    importing a different stack
  • Imported containers become ordinary module-managed containers; later edits
    to the source Compose file are not synchronized
Pods
  • Per-domain and global pod tabs with configurable columns
  • Create, clone, view, start, stop, delete, and bulk lifecycle actions
  • Pod details view with member container summaries
  • Pod-level logs view plus member-container logs and console links
  • Support for creating containers directly inside an existing pod in the
    matching runtime context
Runtime modes
  • Image user (rootless) [default]: Podman runs rootless as the virtual
    server owner, and containers keep the image’s own user model
  • Domain user (rootful): Podman runs rootful, and containers run as
    the virtual server UID/GID
Runtime mode policy can be exposed as a selector, shown as a fixed note, or
kept hidden while still applying the configured default. Separate Podman
runtime contexts are respected for container discovery, pod discovery, and
network selection.
Networking and proxying
  • Multi-port host-to-container mappings with TCP or UDP
  • Pod-level port publishing for shared pod frontends
  • Automatic host-port allocation from a configurable base
  • Optional reverse proxy path mapping for containers and pods
  • Proxy target port selection
  • Proxy host-header forwarding policy support
  • Pod network modes:
    • Default network
    • Specific Podman network
    • Host
    • None
  • Inline create and delete of Podman networks in the selected runtime context
  • Advanced pod network options:
    • network aliases
    • static IPv4, IPv6, and MAC where supported
    • DNS servers, search domains, and resolver options
    • extra host entries
    • no-hosts and no-resolv controls
Storage, environment, and security
  • Multi-volume host path mappings with rw and ro
  • Pod bind mounts with SELinux relabel and ownership-shift controls
  • Domain-home path controls for non-admin contexts
  • Environment entries as NAME=VALUE, including dotted and dashed
    image-specific names such as discovery.type and dashed-name
  • Extra Linux capability controls
  • Runtime hardening flags such as no-new-privileges and read-only root
    filesystem
  • Host access controls for privileged mode, host namespaces, and sensitive or
    outside-home mounts
Resource limits and health checks
  • rootful runtime only for explicit container resource controls
  • Memory, swap, reservation, CPU, PID, cpuset, shared memory, blkio/device
    throttling, and ulimits where supported
  • Optional cgroup-parent mode to inherit limits from the user slice
  • Pod CPU, memory, and shared-memory defaults and limits
  • Container health command, interval, timeout, retries, start period, and
    failure policy
  • Container restart policy and pull behavior
  • Pod restart policy, exit policy, stop timeout, infra container, user
    namespace mode, and shared namespace controls
Image discovery and defaults
  • Registry search UI with keyboard navigation
  • Metadata fetch for selected images
  • Architecture compatibility checks
  • Defaults resolution from:
    • local podman image inspect
    • remote skopeo inspect --config
    • bundled presets.json
    • optional custom presets JSON from module configuration
  • Preset and metadata hints for ports, mounts, envs, health checks, and proxy
    behavior
Logs, console access, and list views
  • Container log viewer
  • Pod log viewer
  • In-container interactive terminal shell
  • Integrated with Webmin xterm backend
  • Domain and container context shown in terminal header
  • Global and per-domain list views for both containers and pods
Access control and UI defaults
  • Owner and reseller access controls
  • Separate direct-container access policy for master administrators, all users,
    or disabled; Application Recipes remain available independently
  • Separate pod access policy for master administrators, all users, or disabled
  • Configurable default list columns for containers and pods
  • Configurable visible panels for container and pod create workflows
  • Module-level defaults for runtime mode, restart behavior, networking,
    security, mounts, extra Podman flags, and other create-time behavior
Module configuration
Config is organized into:
  • General settings
    • Podman command path
    • owner and reseller access
    • default runtime mode
    • runtime mode selector display
    • proxy host-header policy
    • default log lines
  • User interface settings
    • default container list columns
    • default pod list columns
    • visible container panels
    • visible pod panels
  • Registry and discovery
    • default registry pool
    • search result limit
    • presets source mode:
      • use bundled presets only
      • merge bundled presets with custom presets JSON
  • Recipe defaults
    • root web app conflict check before deployment
  • Container defaults
    • direct container access policy
    • restart policy
    • base auto-port
    • user-slice cgroup-parent behavior
    • default extra run flags
    • default capabilities
    • default hardening options
    • default host access options
  • Pod defaults
    • pod access policy
    • infra container and user namespace mode
    • shared namespaces and network mode
    • restart, exit, and stop-timeout policy
    • user-slice limits, CPU, memory, and shared memory defaults
    • mount SELinux and ownership-shift defaults
    • default extra create flags
Presets
presets.json supports curated defaults for known images, including:
  • recommended volume targets
  • recommended env variables
  • recommended port and proxy hints
  • optional notes shown in the UI
Custom presets entered in module configuration are saved in:
/etc/webmin/virtualmin-podman/presets.json
When custom mode is enabled, bundled and custom presets are merged and custom
rules take precedence over bundled rules for matching entries.
If the custom file is empty or invalid, bundled presets are used.
Command-line API
Application recipes and container, pod, image, and network management are also
available through the virtualmin command, so they can be scripted. Each
command is a self-contained script in the module directory, discovered
automatically by the virtualmin wrapper.
Domain-scoped commands take --domain to select the virtual server and support
the standard --multiline, --json, --xml and --name-only output flags
where listings are produced. Runtime-store image commands and network commands
may omit --domain only when the master administrator explicitly selects the
host-global --runtime-mode rootful context. Run any command with --help for
its full option list.
Containers
  • create-container — deploy a container (rich --port, --volume, --env,
    proxy, resource-limit, health-check and security options)
  • modify-container — change settings and recreate the runtime when required
  • delete-container — remove a container (--container name or --all)
  • start-container / stop-container / restart-container — lifecycle
    (single, repeated --container, or --all)
  • reinstall-container — force recreation from saved settings, optionally
    overriding the image-pull policy
  • list-containers — list containers, with status and ports
  • get-container-logs — print recent logs (--tail n)
  • exec-container — run a command (--command) or open an interactive shell
Pods
  • create-pod — create a pod (networking, namespace and resource options)
  • clone-pod — copy an existing pod’s configuration into a new pod
  • delete-pod / start-pod / stop-pod — lifecycle (single, repeated
    --pod, or --all)
  • list-pods — list pods, with status and member counts
  • get-pod-logs — print recent pod logs (--tail n)
Application recipes
  • list-application-recipes — list the recipe catalog with current
    availability and installed deployment details; use --installed or
    --available to filter it
  • deploy-application-recipe — deploy a recipe for a virtual server,
    optionally selecting its deployment variant, deployment name and initial
    login
  • delete-application-recipe — delete an installed recipe and its pod or
    containers; persistent application data is deleted by default but can be
    retained with --keep-data, while downloaded images are always kept
Images
  • list-container-images — with a domain, list that owner’s rootless images
    together with visible host-global rootful images; select one store with an
    explicit runtime mode, or omit the domain for explicit host-global rootful
    output
  • pull-container-image — download an image into the selected domain runtime
    context, or use --runtime-mode rootful without a domain for host-global
    storage; native Podman progress is shown on an interactive terminal and can
    be suppressed with --quiet
  • delete-container-image — remove an image from one selected runtime store
    (--force removes containers in that store first); as with pull/list, an
    explicit rootful target does not require a domain
  • search-container-images — search the configured registry
Networks
  • list-container-networks — list domain-context networks, or use
    --runtime-mode rootful without a domain for host-global networks
  • create-container-network — create a network (subnet, gateway, IPv6, DNS),
    including in the explicit host-global rootful context
  • delete-container-network — remove a network from the selected context
Examples
The recipe API can deploy the same tested WordPress and MariaDB application
shown in the web interface, including generated internal database secrets and
the reverse proxy:
virtualmin deploy-application-recipe --domain blog.example.com \
    --recipe wordpress --login-username admin \
    --login-password CHANGE_ME_ADMIN_PASSWORD
virtualmin list-application-recipes --domain blog.example.com \
    --installed --json
virtualmin delete-application-recipe --domain blog.example.com \
    --recipe wordpress
The following example deploys WordPress and MariaDB in one pod for a dedicated
HTTPS-enabled blog.example.com virtual server. Run these commands as root,
replace both passwords, and adjust the host paths if that domain uses a
different home directory. The example explicitly uses rootful mode because the
plugin then runs both containers as the virtual server’s host UID, matching
the ownership of the bind-mounted directories it creates.
virtualmin create-pod --domain blog.example.com \
    --name wordpress --runtime-mode rootful \
    --port :80/tcp --proxy --proxy-path /
virtualmin create-container --domain blog.example.com \
    --name wordpress-db --pod wordpress --runtime-mode rootful \
    --image docker.io/library/mariadb:11 \
    --volume /home/blog/containers/wordpress/database:/var/lib/mysql:rw \
    --env MARIADB_DATABASE=wordpress --env MARIADB_USER=wordpress \
    --env MARIADB_PASSWORD=CHANGE_ME_DB_PASSWORD \
    --env MARIADB_ROOT_PASSWORD=CHANGE_ME_ROOT_PASSWORD
    --name wordpress-web --pod wordpress --runtime-mode rootful \
    --image docker.io/library/wordpress:latest \
    --volume /home/blog/containers/wordpress/files:/var/www/html:rw \
    --env WORDPRESS_DB_HOST=127.0.0.1:3306 \
    --env WORDPRESS_DB_USER=wordpress \
    --env WORDPRESS_DB_PASSWORD=CHANGE_ME_DB_PASSWORD \
    --env WORDPRESS_DB_NAME=wordpress \
    --env 'WORDPRESS_CONFIG_EXTRA=$_SERVER["HTTPS"] = "on"; define("WP_HOME", "https://blog.example.com"); define("WP_SITEURL", "https://blog.example.com");'
# Complete the WordPress installer at https://blog.example.com/
virtualmin list-containers --domain blog.example.com --json
virtualmin get-container-logs --domain blog.example.com \
    --container wordpress-web --tail 100
virtualmin exec-container --domain blog.example.com \
    --container wordpress-web --command "php -v"
virtualmin pull-container-image --runtime-mode rootful \
virtualmin list-container-images --runtime-mode rootful --json
Remote API
The same commands can be called through Virtualmin’s authenticated remote API.
Pass command options as query parameters and select structured output with
json=1 or xml=1:
curl --user domain-owner \
  'https://host.example:10000/virtual-server/remote.cgi?program=list-containers&domain=example.com&json=1'
Remote access is authenticated and authorized by Virtualmin. Use HTTPS, URL-
encode parameter values, and supply credentials through the caller’s normal
secret-management mechanism rather than embedding them in scripts.
Access control
The master administrator can use every command through the remote API. The
plugin also registers its domain-scoped application recipe, container and pod
commands, plus read-only registry search, for authenticated domain owners and
resellers. Those commands independently enforce the module policy, Virtualmin’s
per-domain edit permission, the module’s allowed-domain ACL, and the separate
direct-container or pod access policy before they access runtime objects.
Recipe commands remain available when direct container management is restricted.
In the image-user (rootless) runtime mode, container operations run as the
virtual server owner.
Rootful and rootless workloads follow the module’s configured runtime policy.
Explicit --runtime-mode selection is master-only. For CLI automation it is
available regardless of whether the corresponding selector is shown in web
forms. For runtime-store image and network commands, an explicit rootful mode
selects host-global Podman storage and therefore does not require --domain;
rootless mode always requires a domain to identify the Unix user’s storage.
Runtime-store image and network commands remain master-only because one store
can be shared by multiple domains, including rootless subservers with the same
Unix owner. The module masks environment values, initial-login passwords and
command-like arguments in Virtualmin’s command audit log.
Mutating commands run any deferred Virtualmin post-actions before reporting
success. A failed web-server or service reload produces a non-zero command
result, including when JSON or XML output conversion is requested.
Requirements
  • Virtualmin Pro with this plugin installed and enabled
  • Podman installed on the host and reachable by the configured command path
  • skopeo recommended for remote image metadata lookups
  • Webmin xterm module access for browser console access
  • Reverse proxy feature enabled on domains that need proxied container or pod
    paths
Notes
  • rootless behavior depends on host capabilities and user-session or systemd
    setup
  • Runtime capability and cgroup behavior can differ between rootful and
    rootless modes
  • Some static network addressing and resource controls are only available in
    supported runtime or network combinations
  • Downloaded image listings, pods, and Podman network choices are runtime-
    context aware
  • Enabling CPU and memory list columns adds an extra runtime stats query
This release began with the original Virtualmin Podman developer preview. Thank you to everyone who tested it and shared feedback along the way.
See the full Virtualmin Podman documentation for usage details.
Can you add this one, its for self hosting remote desktop app
Yes, added in this release:
Excellent thanks.
