Virtualmin installation on OVH fails without clear message why
trying to install Virtualmin on OVH. Root enabled (it’s disabled by default), It exits on step 3 with strange error in virtualmin-install.log:
[ERROR] Something went wrong. Exiting
The last few log entries are:
and it’s EMPTY after that
We need to see what it was doing immediately before that. That can’t possibly be the only entry in the log or on the console.
We also need to know what distro and version you’re installing on!
Hi Joe!
Centos 7
uname -a
Linux vps-xxxxxxxx.vps.ovh.net 3.10.0-1160.90.1.el7.x86_64 #1 SMP Thu May 4 15:21:22 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
login as: root
 python3-setuptools        noarch 39.2.0-10.el7                   base    629 k
 pytz                      noarch 2016.10-2.el7                   base     46 k
 rrdtool                   x86_64 1.4.8-9.el7                     base    440 k
 rrdtool-perl              x86_64 1.4.8-9.el7                     base     42 k
 ruby-irb                  noarch 2.0.0.648-39.el7_9              updates  94 k
 ruby-libs                 x86_64 2.0.0.648-39.el7_9              updates 2.8 M
 rubygem-bigdecimal        x86_64 1.2.0-39.el7_9                  updates  85 k
 rubygem-io-console        x86_64 0.4.2-39.el7_9                  updates  56 k
 rubygem-json              x86_64 1.7.7-39.el7_9                  updates  82 k
 rubygem-psych             x86_64 2.0.0-39.el7_9                  updates  84 k
 rubygem-rdoc              noarch 4.0.0-39.el7_9                  updates 324 k
 sendmail-milter           x86_64 8.14.7-6.el7                    base     71 k
 systemd-python            x86_64 219-78.el7_9.7                  updates 146 k
 systemtap-sdt-devel       x86_64 4.0-13.el7                      base     76 k
 t1lib                     x86_64 5.1.2-14.el7                    base    166 k
 trousers                  x86_64 0.3.14-2.el7                    base    289 k
Transaction Summary
Install  67 Packages (+231 Dependent packages)
Upgrade   7 Packages
Total download size: 296 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
warning: /var/cache/yum/x86_64/7/epel/packages/certbot-1.11.0-2.el7.noarch.rpm: Header V4 RSA/SHA256 Signature, key ID 352c64e5: NOKEY
Public key for certbot-1.11.0-2.el7.noarch.rpm is not installed
Total                                               32 MB/s | 296 MB  00:09.....
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7
Importing GPG key 0x352C64E5:
 Userid     : "Fedora EPEL (7) <epel@fedoraproject.org>"
 Fingerprint: 91e9 7d7c 4a5e 96f1 7f3e 888f 6a2f aea2 352c 64e5
 Package    : epel-release-7-11.noarch (@extras)
Package wbm-jailkit-0.8.202307060202-1.noarch.rpm is not signed
Checking and installing system packages updates: [2023-07-10 00:17:39 UTC] [ERROR] Failed with error: 1
[2023-07-10 00:17:39 UTC] [ERROR] Something went wrong. Exiting.
[2023-07-10 00:17:39 UTC] [ERROR] The last few log entries were:
not sure how to get entire file via Putty
probably this : Package wbm-jailkit-0.8.202307060202-1.noarch.rpm is not signed
nothing to do with ovh.
Should be fixed.
Run dnf clean all and try again. The installer will ask you to confirm a couple of times (once about preinstalled software and once about an existing Virtualmin install), since the system is not in use yet and has no virtual servers it is safe to say y and redo the install.
I did a test on Rocky 9 a few minutes ago so I’m pretty confident everything is good.
hm, now it says on step 2 that “preinstalled software detected - Postfix”
(but i did fresh Centos reinstallation) - by searching i also find folders named postfix
The next sentence in my comment:
sorry for me being dumb!
this time it all went well!
thank you Joe!
