Virtualmin install, error: package is not installed, also, Failed to work out externally visible IP address
OS type and version Alma Linux 9.5
Webmin version REQUIRED
Virtualmin version 7.4.0
Webserver version REQUIRED
I have reinstalled Alma Linux ISO, done no updates, and run the Virtualmin script.
I have seen two errors in the install.
Phase 2 of 4: Setup
Phase 4 of 4: Configuration
[21/21] Configuring Virtualmin
[28/Nov/2024:04:15:45 +0000] Failed to work out externally visible IP address virtual-server/virtual-server-lib-funcs.pl (line 18774)
Error
Cleaning up
Apparently the IP issue has come up before:
So… not sure if these errors are anything to be concerned about or not.
I wouldn’t worry about it!
