sure you can
After adding a new domain ,Apache2 stopped
root@hosts:/etc/apache2# service apache2 restart
Job for apache2.service failed because the control process exited with error code.
See âsystemctl status apache2.serviceâ and âjournalctl -xeâ for details.
â apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2023-12-14 14:02:18 IST; 53s ago
Docs: Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Process: 3155669 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Dec 14 14:02:18 hosts.tag4track.com systemd[1]: Starting The Apache HTTP ServerâŠ
Dec 14 14:02:18 hosts.tag4track.com apachectl[3155679]: AH00526: Syntax error on line 30 of /etc/apache2/sites-enabled/tag4track.com.conf:
Dec 14 14:02:18 hosts.tag4track.com apachectl[3155679]: Invalid command âRewriteEngineâ, perhaps misspelled or defined by a module not included in the server configuration
Dec 14 14:02:18 hosts.tag4track.com systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Dec 14 14:02:18 hosts.tag4track.com systemd[1]: apache2.service: Failed with result âexit-codeâ.
Dec 14 14:02:18 hosts.tag4track.com systemd[1]: Failed to start The Apache HTTP Server.
as the error is on line 30 of the above file you need to fix that but I guess you donât have rewrite enabled
use
a2enmod rewrite
to enable it & restart apache ⊠as you effectively destroyed the apache configuration by your reinstall you are going to work through all the errors that popup ⊠there is no âmagic wandâ to fix it in this case
Done but php is not working
start a new thread as I said earlier you will get loads of errors unless you restore the domain from a backup. You did make a backup ?
backup of /home/user-directory backup I made
using the virtualmin backup utility or something else ⊠if you didnât use the virtualmin backup system you will not have all the configuration files you need ⊠please start a new thread with this new issue
Thankyou everyone , the issue is resolved now ,
<3 community ,
