Virtualim licence - serial number
OS type and version Debian Linux 10
Webmin version 2.001
Virtualmin version 7.2-1 Pro
Hello.
I see a message on server and i dont know what to do.
Warning!
A problem was detected with your Virtualmin license :
An error occurred checking the licence : Invalid host or serial number A renewal can be purchased at Virtualmin Shop
I m not deveroper, so i will try to do this.
This is just a message? If i will not make changes will have problem?
Thank you.
Giannis
It is only two commands, you don’t need to be a developer to install packages from your package manager. That’s basic system maintenance that you need to be comfortable with (even if you use a control panel).
Hello again.
I have another question and i dont know if is servers problem or wordpress.
After create new virtual server i install wordpress.
I can login and work, but cant see pages. Only the virtualmin logo and under constraction.
I have the same problem in 8 sites.
Seems something missing.
Please start new topics for new questions.
I undrestand… My first post.
Thank you
Worked as charm.
