i have added it and test but it replace the network adress.
What is the schema to add it in activated to boot ?
name ? (i have tested Primary network name with “:1”, but error ’ No interface named enp3s0 exists’ with “enp3s0:1” where “enp3s0” is the name of the primary interface)
hardware adresse ?
On Active On boot, first i have no configuration, after reinstall i have a network interface on DHCp, when i add virtual interface, no active on boot i have to apply manually.
I have installed and reinstalled Ubuntu 20.04 and same problem, i have tested with network configuration with fixed ip but nothing change.
I have reinstalled Ubuntu, configure Ip BEFORE installing virtualmin and all VIrtual interface are configured in active on boot tabs, the Virtual interface automatly created on network active on boot and all work.
But after restart, same problem, nothing work …
When i check virtual Ip in list and apply manually, it work …
So the activate on boot on ubuntu 20.04 for virtual Interface doesn’t work
Only solution i have now is to install Ubuntu 16.04 for haven’t this bug
After Test on debian 10, same problem, after fresh install and reboot with just a virtual interface on network configuration. Ip are ok but after reboot i can"t bootup network and i have to resintall.
On active on boot, 3 configuration with eth0 eth1 and eth2 …
There is a mistake in network configuration in the last version …
Holy cow. There’s no way that’s the best solution!
I’d guess there’s still remaining bugs in Webmin’s support for the new Ubuntu network config system (it may be fixed in the next version, which I’m rolling out today). Just configure the network outside of Webmin.
It’s insane to install 16.04 and upgrade to 20.04. That is not a good solution. If you want to use the old network system (which is what this gets you), just use the old network config system. You don’t have to start on 16.04 to do that.
I have tested configure outsite webmin the network and before install virtualmin and the result is exactly the same.
I have tested to rollback to the old network system but after install virtualmin the network config is on the old system and the config active on boot is started with the new configuration with netplan.
On fresh instal how i can rollback to old network system before install virtualmin and make sure this is the good method ?
Ps : i haven’t the latest version of webmin on fresh install, i have 1.955 where latest is 1.960 and in the changelog :
Massive improvements to the YAML parsing in the Network Configuration module, to support more complex Netplan configs.
Can i add directly the Webmin repository or i have to wait for your repository ?
Could you please contact your service provider, and as them about init scripts they setup to run upon reboot? Most likely your network config is overwritten by one of those scripts.
I just tested it with Debian now, and there is no issue at all. I could easily add additional static IP on the interface, and it survived reboots with no problem. The same should be with Ubuntu 20.04.
I have tested fresh install and active on boot is configured but don’t apply on network, when i created a new virtualhost with the FailOver ip the interface is not founded but the ip respond to ping.
