Yesterday I’ve setup a new Server. And it worked like expected.
Today I’ve done some upgrades via Webmin-Panel, and I do a little bit configure the design.
Now I see, that the Widget “Sysinfo” on the dashboard is gone.
If so, set it back to authentic theme and see if that fixes it. If it does, then the settings for your charts isn’t compatible with whatever theme you installed.
Nope, only use the authentic theme so far. Didn’t change it at any time.
Can I export my current authentic-theme settings anywhere, if I ever would like to try to reset the theme for testing purposes?
