I seem to be having the same problem as No CSS when using reverse proxy?. This is a new fairly new VM install, maybe 2 months old. I’ve not messed with any internal files, nor changed any configs outside of the VM frontend. I’m sure this is related to something I’m not setting right, but after searching for weeks I simply can’t seem to figure out why anything running inside Docker (yes… I know, and I’m sorry) doesn’t display properly. If this has been answered, please point me in the right direction. Thanks!
My proxy paths are are as follows:
/portainer https://localhost:9443 This works perfectly.
/myerp http://localhost:8080 This displays, but without CSS.
There are no log errors that I can find. Changing /myerp to https://localhost:8080 displays “Proxy Error: Error during SSL Handshake with remote server”
maybe post your config file.
I don’t know much about the subject but googling some say the maybe a missing forward slash on the end of the proxy_pass line.
Or maybe its the other way round, try both with and without the end forward slash see it fixes it.
After examining the logs above, I tried creating a sub-server and changed the settings on the “Edit Proxy Website” configuration page to Allow Proxy: yes and Proxy to URL: http://localhost:8080/. This configuration worked perfectly.
I don’t mind using a sub-server since this all I do is host my small business and a few personal gaming servers, but I am still left wondering what I’m doing wrong just trying to use the proxy paths. Thoughts?
Arrrggggh… Now I’m getting the exact same thing again with another stack. Even with a sub-server. I don’t even know where to start troubleshooting. Help with this would be greatly appreciated.
A sub-server or a top-level server should be irrelevant. Something weird is happening, if it behaves differently, but I’m having a hard time figuring out what. And, CSS is just another web request, there is nothing special about it…HTML, CSS, and JavaScript and images are all just files. If anything works, everything should work.
So, I guess there’s something weird about the path (i.e. in a directory), or maybe there’s something in your app sucking up the requests and munging them somehow? Redirects or something?
Yea, I’m at a loss as well. Three different docker applications have done this for some reason. As mentioned, I’m sure it’s something I’m setting wrong somehow. I just don’t know what.
I’m about done trying to figure out docker right now. I’ve spent too much time trying to test various applications that I’m behind on other tasks. Think I’ll just wait for VM to release the docker integration that’s been talked and take the time to catch up on other tasks. Thanks guys!
