SYSTEM INFORMATION | |
OS type and version | Ubuntu 22.04.4 LTS, codenamed “jammy.” |
Virtualmin version | Latest (Installed on my vps today(11/06/2024) |
When I use ngix to set up reverse proxy my SSL fails and i’m routed to
When I add a webprefix my css dissapears.
Idk what to do. I’m lost
I use ngix because that’s what i used on another thing i installed. I tought i should probably not use multiple reverse proxy handlers on the same vps but idk?
I’ve seen mention of apache but I just can’t wrap my head around what’s the best course of action here.
Here’s my NGIX setup:
server {
server_name server.example.com;
location / {
proxy_pass http://localhost:10000/;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/server.example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/server.example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = server.example.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
Here’s my webmin setups:
Config:
y_view=0
passwd_uindex=0
passwd_file=/path/to/passwd/file
find_pid_command=ps auwwwx | grep NAME | grep -v grep | awk '{ print $2 }'
tempdelete_days=7
passwd_cindex=2
passwd_mindex=4
ld_env=LD_LIBRARY_PATH
path=/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin
passwd_pindex=1
os_type=debian-linux
os_version=13.0
real_os_type=Ubuntu Linux
real_os_version=22.04.4
lang=en
log=1
referers_none=1
md5pass=0
theme=authentic-theme
product=webmin
os_eol_in=2 years
os_eol=04/01/2027
#webprefix=/
webprefixignored=1
os_eol_about=0
os_eol_db=2.111
os_ext_eol_in=7 years
os_ext_eol=04/09/2032
referers=example.com
relative_redir=0
Miniserv.conf:
port=10000
root=/usr/share/webmin
mimetypes=/usr/share/webmin/mime.types
addtype_cgi=internal/cgi
realm=Webmin Server
logfile=/var/webmin/miniserv.log
errorlog=/var/webmin/miniserv.error
pidfile=/var/webmin/miniserv.pid
logtime=168
ssl=0
no_ssl2=1
no_ssl3=1
ssl_honorcipherorder=1
no_sslcompression=1
env_WEBMIN_CONFIG=/etc/webmin
env_WEBMIN_VAR=/var/webmin
atboot=1
logout=/etc/webmin/logout-flag
listen=10000
denyfile=\.pl$
log=1
blockhost_failures=5
blockhost_time=60
syslog=1
ipv6=1
session=1
premodules=WebminCore
server=MiniServ/2.111
userfile=/etc/webmin/miniserv.users
keyfile=/etc/webmin/miniserv.pem
passwd_file=/etc/shadow
passwd_uindex=0
passwd_pindex=1
passwd_cindex=2
passwd_mindex=4
passwd_mode=0
preroot=authentic-theme
passdelay=1
logout_script=/etc/webmin/logout.pl
failed_script=/etc/webmin/failed.pl
cipher_list_def=1
login_script=/etc/webmin/login.pl
sudo=1
error_handler_404=404.cgi
error_handler_403=403.cgi
error_handler_401=401.cgi
nolog=\/stats\.cgi\?xhr\-stats\=general
ssl_redirect=0
all help is really appreciated
