| SYSTEM INFORMATION | |
| OS type and version | ubuntu20.04.6 |
| Virtualmin version | 7.7 pro |
hello can anyone hellp me im trying to connect to wordpress to setup the installstion i also get the same when i try to connect to my roundcube server too
yes i have done that and its showing the same as yours
So have your routers changed?
no they are still the same ones as before nothing has changed
IP hasn’t changed?
no i have checked everything
You used “whats my ip” to test the public ip
yes its still saying the same ip address for the public ip
No idea then. Something is blocking traffic to VM
i have checked my firewll on virtualmin and it looks ok to me
VW firewall by default should work fine. VM local IP is the same?
I thought you had a static ip but it appears to have changed but what is the website ? Wordpress or something else
yes i havent changed anything except i had to do a freash install of ubuntuserver and webmin/virtualmin thats the only thing i have done everything else like the network settings on the sky hub and on the router has stayed the same
its wordpress
Local ip is still 192.168.50.87 for the vm
