It’s been powered on since I installed it on Monday. Can I just power it off or is there a certain way I should do it. Like I said I am very very new to this.
just type reboot
Well I rebooted it and I am still locked out from the interface
This looks like an install of webmin and not virtualmin, this would explain the lack of fail2ban, it could also mean that firewalld is also not installed and the firewall is ufw. The other point is this appears to be a local install and not a vps/remote install so perhaps we need to look at this differently
Yes I’m pretty sure this is webmin not virutalmin
How did you install webmin/virtualmin ?
I copied commands from this website How to Install Webmin on Ubuntu 24.04 | Vultr Docs
ok, try the command virtualmin list-domains
That doesn’t work because I’m pretty sure this is just webmin
ok, maybe port 10000 is blocked.
try sudo ufw allow 10000
else stop the service
What is the output of
service webmin status ?
Says active and other things say enabled
How do I stop the service?
not 100% I dont use it
first try sudo ufw status going on there docs
It says inactive
opps, that different to docs then. maybe you do have firewalld then.
It doesn’t say anything about ports being open. It just says Status: inactive, after I did sudo ufw status
does systemctl status firewalld or service status firewalld
work?
It said that it started up firewalld service. But when I check the status it says unrecognized service
Maybe I can try logging in? I sent a PM
