System hostname
web1.smtp-jet.com (216.18.219.188)
Operating system Ubuntu Linux 20.04.1
Webmin version 1.970
Usermin version 1.812
Virtualmin version 6.14 Pro
Can I get help with the following issue.
This post explains the issue:
Opencart Script
I have a simple 3 domain system.
web1 there is nothing on it. It is a webserver and nothing currently installed.
for the SQL DB credentials I used the web1 credentials on the screenshot posted.
For email address I just added an existing email address.
I get a server 500 error and I am not sure why.
I would assume at this point it is user error, LOL , but your help is appreciated.
As the post claims, the database looks like it is there, but fails during install, but then you can go to serverxyz.com/opencart and get to the installer but I cannot get it to save settings, and complete install.
Then when clicking continue it gives the server 500 error.
During setup, it passes all pre-requisites, writable directories, files, etc…
but I would get server 500 error, or right away get
“Fatal error: Uncaught Exception: Error: Variable 'sql_mode’ can’t be set to the value of 'MYSQL40 '”
My first thought was maybe another server setting or PHP setting that needed changed.
