hi guys,
Having a problem running an automated installer script on a sub virtual server.
-primary server is domain.com (has wordpress website on it)
-sub virtual server is shop.domain.com (trying to install opencart)
I am able to do this manually, however, i just want to see if there is a way in order to install opencart using the automated script that does not throw the following error…
*Found https://github.com:443/opencart/opencart/releases/download/3.0.3.2/opencart-3.0.3.2.zip in cache ..*
Configuring webserver PHP settings …*
… already done.*
Restarting PHP-FPM server …*
… done*
Now installing OpenCart version 3.0.3.2 …*
Database setup failed*
More information on using this script can be found at http://www.opencart.com/.*
… installation was only partially complete.*
Re-loading Webmin …*
… done*
The database has actually been created in Virtualmin, however, tables are empty.
