Need to delete virtual sever
I am new on this field and I have created so many virtual sever and also sub -server for education purpose from virtualmin “create virtual server” but now i have to delete not all, but some of them, but i can’t find any option or solution to remove/delete virtual server and sub -server in webmin/virtualmin. there is any option to delete/remove virtual server and sub-server or would you help help?
Hello @danish11 and welcome to the community.
To delete a virtual server:
  1. select the domain from the drop down list of domains on the top left corner of Virtualmin
  2. click Disable and Delete, then click Delete Virtual Server
Hello Calport,
Thanks for your response, it is really simple but i can’t find it. really thanks for your help.
Danish
Dear Calport,
i have another issue, i setup twice sub server/ subdomain form vertualmin → create virtual server → sub server just by typing domain name and waited for 7/8 days for dns setup, subdomain is showing on domain list and also in file manager all default files are showing in home/maindomain/domains/subdomain/public_html but still getting same error sever not found. would you help with this?
Hello @danish11 ,
Your question is not very clear. Do you mean getting an error when you enter the domain address in the browser or where are you getting the error? In short what are you trying to do?
Please start new topics for new questions, @danish11
yes, i mean getting an error when you enter the domain address in the browser or where are you getting the error?
Ok. started already, Sever Not Found Error
