Sever Not Found Error
I am new on this field.i setup twice sub server/ subdomain form vertualmin → create virtual server → sub server just by typing domain name and waited for 7/8 days for dns setup, subdomain is showing on domain list and also in file manager all default files are showing in home/maindomain/domains/subdomain/public_html but still getting same error “server not found” . would you help with this?
@danish11,
Are you hosting DNS or using third party?
What is the domain/sub-domain you are trying to access?
Best Regards,
Peter Knowles | TPN Solutions
Professional, Affordable IT Support - https://tpnassist.com
Hosting Dns and trying to access is o.gigton.com
I hope we get solution Here
@danish11,
The domain gigton.con has its dns hosted by CloudFlare. You need to manage the records with their service, setting up dns records in Virtualmin will be ignored.
If you would like to host your own dns I can assist you with setting this up at an affordable rate. Contact me if you’re interested.
Best Regards,
