Your system has 7.38 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB.
Postfix is configured to support per-domain outgoing IP addresses.
SuExec cannot be used to run PHP scripts in CGI or FCGId modes : The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI scripts run as domain owners will not be executed.
The following PHP versions are available : 7.4.19 (/bin/php74-cgi), 8.0.6 (/bin/php80-cgi)
The following PHP-FPM versions are available on this system : 7.4.19 (php-fpm) 8.0.6 (php80-php-fpm)
The following PHP execution modes are available : fpm
Webalizer is installed.
Apache is configured to host SSL websites.
MariaDB 10.3.28 is installed and running.
ProFTPD is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and assumed to be running.
Plugin AWstats reporting is installed OK.
Plugin Protected web directories is installed OK.
Using network interface eth0 for virtual IPs.
IPv6 addresses are available, using interface eth0.
Default IPv4 address for virtual servers is .
Default IPv6 address for virtual servers is .
Both user and group quotas are enabled for home and email directories.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
Chroot jails are available on this system
… your system is ready for use by Virtualmin.
@calport I did just get the php to use the version 8 of php. I was able to change the max input vars to 10000, but when looking at the test php file I made, it shows that max input is 1000. I have scrubbed through a lot of ini files and have not found that value. Any recommendations?
