that is not correct place to call that function, see instructions above
What’s with this: Can’t establish a connection to the server at nx1.intrelligent.net:18810.
Check the server status
Check the connection
Web sites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for nx1.intrelligent.net:18810. The certificate is only valid for intrelligent.net.
And Intrelligent doesn’t have one either…
yes it does,
it shows good
The certificate is self-signed. Users will receive a warning when accessing this site unless the certificate is manually added as a trusted certificate to their web browser. You can fix this error by buying a trusted SSL certificate
Common name: *.intrelligent.net
SANs: intrelligent.net
Organization: root
Valid from August 27, 2020 to August 26, 2025
Serial Number: eec910598b383fcb
Signature Algorithm: sha256WithRSAEncryption
Issuer: *.intrelligent.net
. request failed : Web-based validation failed : Failed to request certificate :
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 149, in get_crt
port shows thisL#:
Webmin
You must enter a username and password to login to the server on intrelligent.net
Remember me
port shows thisL#:
Blockquote
What’s this?
do you use virtual server (intrelligent.net), Server Configuration, SSL Certiifcate
to get access to the Lets Encrypt Tab ?
I’m actually starting again. I’ve deleted all domains…
stop deleting eveything, you are going round in circles.
it will take me 10 minutes to sort your problems if I had access to your server, thenyou woudlk see what needs to be done
the image of webmin window I gave above shows you had something right
ok. where do i send info?
you have my email brian@fife
it got deleted with roundcube
.co.uk
my email is from above and that added
O.K. give me a few.
by the way, I still see webmin at the Ip adderss and port you have above
and it has valid ssl
I also tried to send you an email but it is not getting sent to you
