| SYSTEM INFORMATION | |
| OS type and version | Rocky Linux 9.1 |
| Webmin version | 2.001 |
| Virtualmin version | 7.3 |
I have successfully been using Virtualmin to create per-domain SSL certs via Letsencrypt, on my server running Apache, Postfix and Dovecot.
I have not enabled creation of wildcard domains for the certificates.
However, when Virtualmin creates the certificate entries in the configuration files, it also adds wildcard domain entries, which cause undesired behaviour when I have separate certificates for both domain.com and sub.domain.com. For example:
In dovecot/dovecot.conf:
local_name vps3.softins.co.uk {
ssl_cert = </etc/ssl/virtualmin/166734225438488/ssl.combined
ssl_key = </etc/ssl/virtualmin/166734225438488/ssl.key
local_name *.vps3.softins.co.uk {
In postfix/sni_map:
vps3.softins.co.uk /etc/ssl/virtualmin/166734225438488/ssl.key,/etc/ssl/virtualmin/166734225438488/ssl.cert
.vps3.softins.co.uk /etc/ssl/virtualmin/166734225438488/ssl.key,/etc/ssl/virtualmin/166734225438488/ssl.cert
In webmin/miniserv.conf and usermin/miniserv.conf:
ipcert_vps3.softins.co.uk,*.vps3.softins.co.uk=/etc/ssl/virtualmin/166734225438488/ssl.cert
ipkey_vps3.softins.co.uk,*.vps3.softins.co.uk=/etc/ssl/virtualmin/166734225438488/ssl.key
How can I tell webmin/virtualmin NOT to create the entries for *.vps3.softins.co.uk and .vps3.softins.co.uk, and to create the entries ONLY for vps3.softins.co.uk?
I have tried looking in the SSL configuration areas for a likely setting without success.
Thanks,
Tony
