It’s been a long time since I remember seeing something like this. Is the whole partition being mounted read only? Could be the a disk problem and the OS wants you to do a back up and get if fixed before making things worse by doing writes or any thing else.
Use du to find where the usage is, you still have a bit there / has 45G and /home has 48G. What are you hosting as you have alot of useage.
The error is Read Only at /etc/webmin/apache/site I presume that under /
Use filemananger and check the permission on that file, on my system its only a 2K file and set to 644
Yes, I know and entered the correct password sudo/user.
Here, i try to check virtualmin config, error
envy@ns40:~$ sudo virtualmin check-config
Your system has 11.54 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB
[21/Jan/2024:00:02:30 +0000] Require virtualmin-htpasswd/virtual_feature.pl failed : Require apache/apache-lib.pl failed : Failed to open /etc/webmin/apache/site for writing : Read-only file system ../web-lib-funcs.pl (line 10440) ../web-lib-funcs.pl (line 4185) Compilation failed in require at /usr/share/webmin/virtualmin-htpasswd/virtual_feature.pl line 7. ../web-lib-funcs.pl (line 4185)
BIND DNS server is installed
Mail server Postfix is installed and configured
Postfix is configured to support per-domain outgoing IP addresses
[21/Jan/2024:00:02:31 +0000] Failed to open /etc/webmin/apache/site for writing : Read-only file system ../web-lib-funcs.pl (line 10440)
Error
envy@ns40:~$
You just don’t get the options as a user. This is your system isn’t it?
Can you create new virtual server, normally you are limited to one server if non root.
I already posted the result of virtualmin check-onfig
Here it is again
[sudo] password for envy:
[21/Jan/2024:01:16:41 +0000] Require virtualmin-htpasswd/virtual_feature.pl failed : Require apache/apache-lib.pl failed : Failed to open /etc/webmin/apache/site for writing : Read-only file system ../web-lib-funcs.pl (line 10440) ../web-lib-funcs.pl (line 4185) Compilation failed in require at /usr/share/webmin/virtualmin-htpasswd/virtual_feature.pl line 7. ../web-lib-funcs.pl (line 4185)
[21/Jan/2024:01:16:42 +0000] Failed to open /etc/webmin/apache/site for writing : Read-only file system ../web-lib-funcs.pl (line 10440)
Error
