Failed to add system in Cloudmin | No KVM process selected
I just installed cloudmin on newly OS centos 7.6 to manage other virtual servers but getting error while adding KVM Instance.
Error: " Failed to add system : No KVM process selected "
I didn’t Find any setting for KVM Process to add, Please let me know how to fix this.
thanks.
Detailed screenshot of system that am adding
You are using an IP as a hostname could be a problem possibly IDK
This is quite out of date.
This select box is for KVM processes that are already running. You need to use ‘Create KVM Instance’ to create a new kvm instance.
It might happen if KVM is not properly enabled or detected on the server. Make sure virtualization is supported by your CPU and that the KVM modules are loaded on CentOS. Also check if the KVM process is configured correctly in Cloudmin settings.
