DNS issues, need help
OS type and version Ubuntu 20.04.4
Webmin version latest
Virtualmin version latest
I could really use a hand properly setting up the DNS on my system, it was workin alright then i addedd a couple nameserver records then everything changed. The problem its causing Postifx not to function properly, here is the errors i get when i try and get SSL certificate.
Saving debug log to /var/log/letsencrypt/letsencrypt.log. Plugins selected: Authenticator webroot, Installer None.
An unexpected error occurred:
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
    conn = connection.create_connection(
  File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 61, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.8/socket.py", line 918, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 665, in urlopen
    httplib_response = self._make_request(
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 376, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 996, in _validate_conn
    conn.connect()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 314, in connect
    conn = self._new_conn()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 171, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7fa4699f73d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 719, in urlopen
    retries = retries.increment(
  File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 436, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fa4699f73d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fa4699f73d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Please see the logfiles in /var/log/letsencrypt for more details.
here is error log
2022-05-01 01:18:21,070:DEBUG:certbot.main:certbot version: 0.40.0
2022-05-01 01:18:21,070:DEBUG:certbot.main:Arguments: ['-q']
2022-05-01 01:18:21,070:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-05-01 01:18:21,076:DEBUG:certbot.log:Root logging level set at 30
2022-05-01 01:18:21,076:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-05-01 01:18:21,081:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli._Default object at 0x7f4b847aee80> and installer <certbot.cli._Default object at 0x7f4b847aee80>
2022-05-01 01:18:21,087:INFO:certbot.renewal:Cert not yet due for renewal
2022-05-01 01:18:21,087:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer None
2022-05-01 01:18:21,089:INFO:certbot.renewal:Cert not yet due for renewal
2022-05-01 01:18:21,089:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer None
2022-05-01 01:18:21,091:INFO:certbot.renewal:Cert not yet due for renewal
2022-05-01 01:18:21,091:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer None
2022-05-01 01:18:21,093:INFO:certbot.renewal:Cert not yet due for renewal
2022-05-01 01:18:21,093:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer None
2022-05-01 01:18:21,095:INFO:certbot.renewal:Cert not yet due for renewal
2022-05-01 01:18:21,095:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer None
2022-05-01 01:18:21,095:DEBUG:certbot.renewal:no renewal failures
2022-05-01 08:44:25,342:DEBUG:certbot.main:certbot version: 0.40.0
2022-05-01 08:44:25,342:DEBUG:certbot.main:Arguments: ['-a', 'webroot', '-d', 'hostmax.online', '-d', 'www.hostmax.online', '-d', 'mail.hostmax.online', '-d', 'admin.hostmax.online', '-d', 'webmail.hostmax.online', '--webroot-path', '/home/hostmax.online/public_html', '--duplicate', '--force-renewal', '--manual-public-ip-logging-ok', '--non-interactive', '--agree-tos', '--config', '/tmp/.webmin/762717_2202452_1_letsencrypt.cgi', '--rsa-key-size', '2048', '--cert-name', 'hostmax.online']
2022-05-01 08:44:25,342:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-05-01 08:44:25,348:DEBUG:certbot.log:Root logging level set at 20
2022-05-01 08:44:25,348:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-05-01 08:44:25,348:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2022-05-01 08:44:25,348:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Interfaces: IAuthenticator, IPlugin
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x7f8e2d584e20>
Prep: True
2022-05-01 08:44:25,348:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Authenticator object at 0x7f8e2d584e20> and installer None
2022-05-01 08:44:25,348:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2022-05-01 08:44:25,350:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/481816020', new_authzr_uri=None, terms_of_service=None), bccbd6d6434f68856f8096f5c7376fe3, Meta(creation_dt=datetime.datetime(2022, 4, 4, 5, 11, 26, tzinfo=<UTC>), creation_host='ubuntu.hostmax.online'))>
2022-05-01 08:44:25,351:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2022-05-01 08:44:25,351:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2022-05-01 08:44:27,287:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
2022-05-01 08:44:27,288:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sat, 30 Apr 2022 22:44:27 GMT
Content-Type: application/json
Content-Length: 658
Connection: keep-alive
Cache-Control: public, max-age=0, no-cache
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800
  "keyChange": "https://acme-v02.api.letsencrypt.org/acme/key-change",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
    "website": "https://letsencrypt.org"
  "newAccount": "https://acme-v02.api.letsencrypt.org/acme/new-acct",
  "newNonce": "https://acme-v02.api.letsencrypt.org/acme/new-nonce",
  "newOrder": "https://acme-v02.api.letsencrypt.org/acme/new-order",
  "revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
  "wb-F0mK5dUM": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2022-05-01 08:44:27,293:DEBUG:certbot.renewal:Auto-renewal forced with --force-renewal...
2022-05-01 08:44:27,293:INFO:certbot.main:Renewing an existing certificate
2022-05-01 08:44:27,321:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0010_key-certbot.pem
2022-05-01 08:44:27,322:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0010_csr-certbot.pem
2022-05-01 08:44:27,322:DEBUG:acme.client:Requesting fresh nonce
2022-05-01 08:44:27,322:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2022-05-01 08:44:27,544:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2022-05-01 08:44:27,545:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: 0101zPbe_n7fencma2L7LDjESE3jdeoa_1WhVq9BPL3wDdQ
2022-05-01 08:44:27,545:DEBUG:acme.client:Storing nonce: 0101zPbe_n7fencma2L7LDjESE3jdeoa_1WhVq9BPL3wDdQ
2022-05-01 08:44:27,546:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "hostmax.online"\n    },\n    {\n      "type": "dns",\n      "value": "www.hostmax.online"\n    },\n    {\n      "type": "dns",\n      "value": "mail.hostmax.online"\n    },\n    {\n      "type": "dns",\n      "value": "admin.hostmax.online"\n    },\n    {\n      "type": "dns",\n      "value": "webmail.hostmax.online"\n    }\n  ]\n}'
2022-05-01 08:44:27,549:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDgxODE2MDIwIiwgIm5vbmNlIjogIjAxMDF6UGJlX243ZmVuY21hMkw3TERqRVNFM2pkZW9hXzFXaFZxOUJQTDN3RGRRIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
  "signature": "gAvmxySxf7N4xDR__tR2FmYtLIJ-IXfdATVcxnefdAO1OKNGo9yEM9Oj0OkEne1Y0RUW3X69kPKTAMdARBhwsFXSG1CVZXqg6RUoGyjQ6uQEzgg5Q2ClC7eYlCdmrDF47s_hm1Wi3l0Ahp_fMl1C6EhCS193hMZABItfTMj6eY7pk7ZF8X78YPtW3E51xhD1p_0DMkaXjhoRRe0aneD7q0SbtBOA5jHLgugMbTWufihfFcMsLqtiaWUhae74BVgtBqUetsS0Boz7Ce_aaP68qJv7fE68677PKNbwiHDGQBe8NZ_kg1RaHzYRFBbmKkGS1Lm_SZ1I5DVPDDfbAqqh2A",
  "payload": "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"
2022-05-01 08:44:27,977:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 902
2022-05-01 08:44:27,978:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 902
Boulder-Requester: 481816020
Location: https://acme-v02.api.letsencrypt.org/acme/order/481816020/84713006967
Replay-Nonce: 0102ms1AiJTs2glg9S-nRyZOjzU2DnqUAtv8n0NYcNxcrLE
  "status": "ready",
  "expires": "2022-05-04T05:11:29Z",
  "identifiers": [
      "type": "dns",
      "type": "dns",
      "type": "dns",
      "type": "dns",
      "type": "dns",
  "authorizations": [
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635030890",
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635030900",
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635092970",
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635092980",
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635030930"
  "finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/481816020/84713006967"
2022-05-01 08:44:27,978:DEBUG:acme.client:Storing nonce: 0102ms1AiJTs2glg9S-nRyZOjzU2DnqUAtv8n0NYcNxcrLE
2022-05-01 08:44:27,979:DEBUG:acme.client:JWS payload:
b''
2022-05-01 08:44:27,982:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/94635030890:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDgxODE2MDIwIiwgIm5vbmNlIjogIjAxMDJtczFBaUpUczJnbGc5Uy1uUnlaT2p6VTJEbnFVQXR2OG4wTlljTnhjckxFIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My85NDYzNTAzMDg5MCJ9",
  "signature": "f5FOIyZjA_vhdp1d3qTgS3A6gfWUHSXisPSEQHPhoGJncxYsO_MGdJdyAtWQGahbk5G-1Z_TRWoVSbwdodGYGZ8FasLu6SipzCYr8NV2BGqxQp_IdWpiaVrDcjVfMawYjZCqiA4hjEp2Se-2eShRT1ru161Nf_uVmMA-ogj5R127eQ0jhXGtmFstU-hfLIVnecfhdIvmSxT7o1Y5EvPdnGGQ_tcadDgU8Q2gYjsl-7y50-jnPX3tJ_Il-UujZxbXbRuHuOZ32C85j7NPfA_CJyK-haCkmOHOqJHNsyBZpJV1NvOOoXuiEc4EDDRVZU3fXTNTUqGOK5G7fWHUM0YUIg",
  "payload": ""
i posted this few days ago. still no reply, what is the point of purchasing pro version?
The versions while latest yesterday could be other then latest today. :wink:
How can support know what you changed with that information? So how and which added?
Check DNS tools there are lot on the web first to find out some more info’s i suggest.
This error is self explanatory, and not related to Virtualmin itself.
Please have a look at this thread, it must help:
Also, as a Pro user you can open a support ticket as described here.
