Disable letsencrypt renew of certificates for disabled domains
I do have 2 Domains, which generally used letsencrypt but which are disabled at the moment.
Virtualmin notice about the expired certificates:
If a domain is disabled, the letsencrypt certificate validation should also be paused.
@Jamie, what do you think about this suggestion?
Yes, that’s a good idea … I’ll do that.
Perfect, thanks a lot!
Just general curiosity, how long from git commit to showing up in the wild on installed systems? Next pushed revision?
