Explain how this is not working? You just showed us 2 emails that where sent successfully to gmail.
You need to ask your provider if they support giving you an rDNS/PTR for the ipv6 they gave you.
Than add the ipv6 to your DNS AAAA Records. You should be good to go.
Connection could not be established with host âherbsofafrica.com:587â: stream_socket_client(): Unable to connect to herbsofafrica.com:587 (A connection attempt failed because the connected party did not properly respond after a period.
Then I tried using OUTLOOK with the same credentials, and it gives me error also
Concerning rDNS/PTR for the ipv6, is this what you mean ?
I found this in my server domain record. Not sure how to use it.
I am also using cloudflare for DNS.
This has to be a user setup on the Virtualserver account. Just go into email settings on Virtualmin for this account and create a user that will be able to have access to email functions. You can create a user for that account with any name and give it the alias for support@yourdomain.
please iâm sorry, donât be offended. I donât know how to do this and also where to do it.
is it on cloudflare, or on my server, or both. And How ?
The RDNS gets setup with whomever is your IP provider for the server. You give them your postfix hostname.
If cloudflare is your DNS provider for your domain name? Than set up the ipv4 and ipv6 to point to your postfix hostname.
Does cloudflare provide the IP for your server? Only enter PTR if they do.
Other wise, make sure you have an A record for your hostname and AAAA record for your hostname in cloudflare.
If cloudflare DOES NOT provide the IP for your server? Than contact support for whomever does.
Ask the IP provider to create a rDNS/PTR for your hostname.
Also, Donât forget to follow instructions above about setting MAIL_USERNAME=
This has to be a user on that Virtualserver.
concerning the instruction to ensure the mail_username is a userâŠ
it was already a user on the machine, but with only Email Login Access.
Now I enabled other login access as shown in the image below
Youâve mentioned at least two different problems here.
Title is âcanât connect SMTPâ. What canât connect to SMTP? Is that when you try to connect using a mail client like Thunderbird or Outlook? That would be explained by the authentication error in the log you included. So, make sure youâre using the actual full username (the default is user@domain.tld and not just user). You can find the exact username on the Edit Users page. Also, obviously, the password much be right.
This one we may not be able to answer. I donât know how to troubleshoot why GMail considers something spamâŠit may just look like spam to Google, even if all the technicals are right. Does a simple test email make it through?
Note this is unrelated to your authentication error.
Well you removed the information about your setup preferences for the script to access your email server. I suggest like someone had mentioned above to recheck the settings and make sure your entered to right credentials.
This username and password (hidden) are correct. I use it to login to usermin and it works, I use it to login to roundcube and it works.
But its not working for SMTP connection.
Connection could not be established with host âherbsofafrica.com:587â: stream_socket_client(): Unable to connect to herbsofafrica.com:587 (A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond)
$ nmap herbsofafrica.com
Starting Nmap 7.95 ( https://nmap.org ) at 2024-06-03 15:50 CDT
Nmap scan report for herbsofafrica.com (172.67.149.107)
Host is up (0.021s latency).
Other addresses for herbsofafrica.com (not scanned): 104.21.29.153 2606:4700:3032::6815:1d99 2606:4700:3030::ac43:956b
Not shown: 996 filtered tcp ports (no-response)
PORT STATE SERVICE
80/tcp open http
443/tcp open https
8080/tcp open http-proxy
8443/tcp open https-alt
Nmap done: 1 IP address (1 host up) scanned in 5.14 seconds
You only have a handful of ports open, and they donât include any of the mail ports.
Are you behind Cloudflare or some other proxy thing or are you on a network connection that otherwise blocks mail ports? If so, you need to make that not so for mail addresses. You canât run mail through Cloudflare (and you canât run mail on a consumer network connection or on some cloud providers without jumping through some additional hoops).
