Joe
January 21, 2023, 11:17pm
2
When you enable a website now, you always get SSL (TLS).
Sorry I didn’t finish before I posted.
see if this shows
So the Apache SSL webite enable/disable setting is no longer available?
Joe
January 21, 2023, 11:36pm
5
From the changelog:
Added support for enabling an SSL website automatically
Howdy all,
I’ve rolled out version 7.5 of the Virtualmin virtual-server module.
Changes since 7.4 (7.4 was not published to Virtualmin repos due to bugs):
Fixed the way PHP extensions are enabled when installing scripts
Cpanel migration fixes for parked domains
Bugfixes for setting the limit on the number of processes in PHP FPM mode
Added buttons to start and stop the SASLauthd server
Implemented support for backups to Azure Blob Stora…
I guess that could have been more clear…but, yes, since there is no reasonable situation where one would not want an https site, and we’re trying to simplify the UI (every checkbox/option/etc. is something somebody can get wrong) that’s now always enabled.
Ok thanks, the Update must not of effected my current machine.
system
Closed
January 29, 2023, 11:39pm
7
