| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Server 18.04.06 |
| Webmin version | 1.984 |
| Virtualmin version | 6.17-3 |
Running in a QEMU/KVM VM. The host machine is running Ubuntu Server 20.04.
I am running Apache with around 5 domains. No Mail Server. DNS is running on another box.
BIND9 is off and disabled at boot.
Since updating my system from the command line using sudo apt-get update, …upgrade, …dist-upgrade Virtualmin seems to have lost all information regarding the few domains associated with the system.
When I click [ Re-check and refresh configuration ] the following is given:
**The status of your system is being checked to ensure that all enabled features are available, that the mail server is properly configured, and that quotas are active ..**
Your system has 4.83 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB.
Virtualmin is configured to setup DNS zones, but this system is not setup to use itself as a DNS server. Either add 127.0.0.1 to the [list of DNS servers](https://192.xxx.xxx.xxx:10000/net/list_dns.cgi?xnavigation=1), or turn off the BIND feature on the $2 page.
A problem was found with your Postfix virtual maps : No map sources were found in the [Postfix configuration](https://192.xxx.xxx.xxx:10000/net/list_dns.cgi?xnavigation=1)
**.. your system is not ready for use by Virtualmin.**
The web server is functioning and I can SSH into the VM and I can send mail out.
I have looked at several post but I have gotten no where.
Any help would be greatly appreciated.
