So there are a few problems when I try to install Zen Cart v1.3.8a.
Errors:
MySQL Support = OFF
Database not supported
CURL not compiled into PHP - notify server administrator
PHP GD Support = OFF
GD Version = GD
PHP cURL Support = OFF
CURL NON-SSL Capability = CURL not compiled into PHP - notify server administrator
CURL SSL Capability = CURL not compiled into PHP - notify server administrator
CURL NON-SSL Capability via Proxy = CURL not compiled into PHP - notify server administrator
CURL SSL Capability via Proxy = CURL not compiled into PHP - notify server administrator
PHP Output Buffering (gzip) = OFF
I don’t understand why I’m getting these errors.
So far I love Virtualmin. I was planning on using the GPL version until I had more than 2 domains running.
If you installed using install.sh, you should have some of those modules already (certainly MySQL). You can get GD support from yum or apt-get (you haven’t mentioned your OS or version, so I can’t give any specific advice).
I’m not sure about curl support in PHP. I’m not sure where that usually comes from.
The rest of it is just configuration options in php.ini.
I am using Ubuntu 8.04LTS.
I used install.sh and MySQL is installed…
A little background on this setup:
I installed the OS fresh for this setup, with only DNS and SSH installed. I setup DNS, and then wget the install.sh and ran it. The install appeared to go find, and the system was setup in a couple of mins (amazing). I added one website, and then downloaded the latest version of zencart and uploaded it to the server. I set permissions for the required files, and renamed the configure files to be used by zencart. I went to the installer and that is where I am getting snagged on it Database not supported (MySQL).
I see what your saying about configuration options in php.ini
Yeah, I don’t think I’ve seen the install.sh actually install the php5-mysql package previously – I’m not sure if that’s a bug, or if it’s recently begun doing so.
In any case, try logging in over SSH, and type:
apt-get install php5-mysql php5-curl
Those packages contain two of the modules the ZenCart install is asking for.
I appreciate the help, I had previously assumed to install the packages that were missing (curl) but it hadnt worked. I probably installed the wrong package. But anyways. That worked.
You guys have done an excellent job and once I have some more websites up and If I ever get any clients I definitely be upgrading to pro so my clients can use it.
