.. your system is not ready for use by Virtualmin
Operating system: 20.04
OS version:
Fresh install 25gb Digital Ocean asked for swap file. Installed run thrue wizzard, this comes up.
Your system has 981.33 MiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB.
Postfix is configured to support per-domain outgoing IP addresses.
Apache configuration errors were found :
(2)No such file or directory: AH02291: Cannot access directory ‘/var/log/virtualmin/’ for error log of vhost defined at /etc/apache2/sites-enabled/Latvijai.lv.conf:1 AH00014: Configuration check failed Action ‘configtest’ failed. The Apache error log may have more information.
This is a duplicate of Clean install gives when Apache is installed before I install Virtualmin
Please do not clutter the forums with duplicate messages. Please continue the original thread / topic instead of creating a new one if the error you see is identical to the previous one you had posted about.
