I know this topic has been posted here numerous times, but it didn’t solved my problem.
I’m using the latest Virtualmin and Webmin version and there are running 28 virtual servers.
I’ve mounted the /home to use the quota and I’ve set up all the quota limits. But the Quota panel shows me for each Virtual Server a usage of 56kb, but in reality in there there are some hundred of MB. I’ve already run the quota check several times, but still the same.
But the strange: For 3 users the quota gets listed correctly (root, mainuser and #1000).
This is what I see when I choose a virtual Server and cklich on Edit Virtual Server > Quota…
Home disk space used (including sub-servers) 0 bytes (136 kB by server administrator, 0 bytes by mail / FTP users)
Space used by databases 1.72 MB (1.72 MB in this server, 0 bytes in sub-servers)
Just to be sure – the files you’re seeing for these users where the quotas aren’t registering anything – are those files definitely owned by those users?
For example, if you have the user “ftp_example”, and there’s 500MB of files in that user’s directory, but they’re all owned by “root”, I don’t believe they would go against the ftp_example user’s quota.
It’s possible they can get out of sync – try going into Limits and Validations -> Check Disk Quotas, and running a check with both “Both users and groups” enabled.
Still no solution for this? Could it be a problem with permission of something or could it be a bug? I did aleady the chown command for each user and that solved the problem from post 1,but it didn’t help here.
you can try deleting the quota.user and quota.group files in your /home, then try to enable quotas again, then re-run the configuration check in Virtualmin. Per haps it will pick up.
what’s with the root stuff in your /home ? Should that be there?
The root there are just the permissions. I don’t know where thy go normally. But is there a file where i can see which directories he uses to calculate the quota?
the soft limit will tell the user he has reached the limit, nothing else will happen, per haps send out an email. He can exceed the limit
the hard limit will prevent the user to exceed the given quota
1 approach to use this is, you could give a soft limit of, let’s say, 50 mb and then a hard limit of 75 mb, where the 50mb could be a warning to the user
