This is my first time configuring virtualmin/webmin and i cannot complete configuration postfix I have configure ssh,mysql, apache, dovecot and BIND DNS right. I have configure two domains, main domain and other virtual domain. but when i have configured postfix i have checked send email from server to other mail using roundcube installed in one domain and is right I can configure POP3 /SMTP account in client email right but when i try send email from gmail to new account i recived this error: This is the mail system at host prod-node1.xxx.es.
I’m sorry to have to inform you that your message could not be delivered to one or more recipients. It’s attached below.
For further assistance, please send mail to postmaster.my postconf -n command is: [root@prod-node1 ~]# postconf -n alias_maps = hash:/etc/aliases allow_percent_hack = no broken_sasl_auth_clients = yes command_directory = /usr/sbin config_directory = /etc/postfix daemon_directory = /usr/libexec/postfix data_directory = /var/lib/postfix debug_peer_level = 2 debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5 home_mailbox = Maildir/ html_directory = no inet_interfaces = all inet_protocols = all mailbox_command = /usr/lib/dovecot/dovecot-lda -d "$USER" mailbox_size_limit = 0 mailbox_transport = lmtp:unix:/var/run/dovecot/lmtp mailq_path = /usr/bin/mailq.postfix manpage_directory = /usr/share/man mydestination = $myhostname, localhost.$mydomain, $mydomain, prod-node1.xxx.es mail.$mydomain mydomain = xxx.es myhostname = prod-node1.xxx.es myorigin = $mydomain newaliases_path = /usr/bin/newaliases.postfix readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES recipient_bcc_maps = hash:/etc/postfix/recipient_bcc sample_directory = /usr/share/doc/postfix-2.10.1/samples sender_bcc_maps = hash:/etc/postfix/bcc sender_canonical_maps = hash:/etc/postfix/canonical sender_dependent_default_transport_maps = hash:/etc/postfix/dependent sendmail_path = /usr/sbin/sendmail.postfix setgid_group = postdrop smtp_use_tls = yes smtpd_recipient_restrictions = permit_mynetworks permit_sasl_authenticated reject_unauth_destination smtpd_sasl_auth_enable = yes smtpd_sasl_security_options = noanonymous unknown_local_recipient_reject_code = 550 virtual_alias_maps = hash:/etc/postfix/virtual virtual_transport = lmtp:unix:/var/run/dovecot/lmtp Please can someone help me , i don't mind use LMTP or other protocol only want configure in some way the postfix&dovecotIf you do so, please include this problem report. You can delete your own text from the attached returned message.
The mail system
(expanded from ): host prod-node1.xxx.es/var/run/dovecot/lmtp] said: 550 5.1.1 User doesn’t exist: pp2-cartavinos.es@prod-node1.xxx.es (in reply to RCPT TO command)
Final-Recipient: rfc822; pp2-cartavinos.es@prod-node1.xxx.es Original-Recipient: rfc822;pp2@cartavinos.es Action: failed Status: 5.1.1 Remote-MTA: dns; prod-webext1.xxx.es Diagnostic-Code: smtp; 550 5.1.1 User doesn’t exist: pp2-cartavinos.es@prod-node1.xxx.es
domain is xxx.es and server name (hostname -f) is prod-node1.xxx.es other virtual domain is cartavinos.es and i have created email pp2@cartavinos.es
