Wp workbench defaults
| SYSTEM INFORMATION|
|OS type and version|Ubuntu Linux 24.04.3|
|Webmin version|2.520|
|Virtualmin version|7.50.0 Professional|
|Related packages| wp workbench|
how to set up default parameters for WP Workbench
for example : (change default circled values )
Do you mean it’s set to default like that after a clean installation of WordPress using Virtualmin?
Yes, when using workbench i install wordpress and then i get those parameters.
how to change those default parameters so i don’t have to go each new wordpress installation every time to change manually those parameters.
There’s no UI option to do it right now. However, I’ll add this to my to-do list to make it configurable via templates.
At the moment, the best option you have is to use WP Workbench CLI after each WordPress instance is installed, as shown here:
Furthermore, note that when you change the memory limit in WP Workbench, it will also affect the memory limit for the entire PHP-FPM pool for the domain. Currently, there’s no option to exclude this, but I’ll add it to my to-do list as well.
thanks, the product is wonderful but more options are necessary to automat estuff and do not waste time, wich is priceless
thanks in advance
Thanks! Sure, I’ll add it soon and update this ticket…
