WordPress Permalink Problem with Nginx webserver
I recently rebuilt my VPS with centos 6, virtualmin and Nginx web server.
I am unable to make use of WordPress Permalinks. Default permalink is working but when I activate a custom permalink the following error is displayed
404 Not Found nginx/1.0.9
nginx/1.0.9
I googled and installed a compatibility plugin but I am getting the same error.
I don’t want to do anything which will harm the server. So I require a possible correct solution for this.
Please help
Regards,
Anand
Hello there,
I came upon this thread while searching for this, too, but then I remembered that I already did it on another Wordpress site.
So, to do fix this you need to edit the domain’s Nginx configuration file. If you are a beginner, I wouldn’t suggest doing it because you can break stuff.
For example, your domain is mywordpress.com – what you need to do is login via SSH and open the file /etc/nginx/sites-available/mywordpress.com, and between:
    fastcgi_param HTTPS $https;
    location ~ \.php$ {
add the following:
    fastcgi_hide_header X-Powered-By;
    # enforce NO www
    if ($host ~* ^www\.(.*))
            set $host_without_www $1;
            rewrite ^/(.*)$ $scheme://$host_without_www/$1 permanent;
    # unless the request is for a valid file, send to bootstrap
    if (!-e $request_filename)
            rewrite ^(.+)$ /index.php?q=$1 last;
Save the file, restart Nginx, and you should be fine.
Good luck, googlers :slight_smile:
Thank you for this! I am trying out my Wordpress on Virtualmin using Nginx, your solution fixed the broken permalinks issue.
It worked for me too; just needed to clean up the formatting a little. I’m brand new to Nginx, so this was a big help.
enforce NO www
if ($host ~* ^www.(.)) {
rewrite ^/(.
if (!-e $request_filename) {
