During a new installation of WordPress I get the following message: “Your PHP installation appears to be missing the MySQL extension which is required by WordPress.”
I specify that the PHP-Mysqlnd library is installed .
System:
CentOS Linux 8.2.2004
Webmin 1,953
Virtualmin 6.10
Nginx
PHP 7.2
Log error Nginx:
[error] 19696 # 0: * 16 FastCGI sent in stderr: “PHP Warning: Use of undefined constant WP_CONTENT_DIR – assumed ‘WP_CONTENT_DIR’ (this will throw an Error in a future version of PHP) in / home / myvideoimage / public_html / wp -includes / load.php on line 141 “while reading response header from upstream, client: 192.168.1.12, server: myvideoimage.com, request:” GET /wp-admin/install.php HTTP / 1.1 “, upstream:” fastcgi : // unix: /var/php-nginx/159611529162207.sock/socket: “, host:” 192.168.1.13 ”
2020/08/01 09:44:09 [error] 19696 # 0: * 16 FastCGI sent in stderr: “PHP Warning: Use of undefined constant WP_CONTENT_DIR – assumed ‘WP_CONTENT_DIR’ (this will throw an Error in a future version of PHP ) in /home/myvideoimage/public_html/wp-includes/load.php on line 141 “while reading response header from upstream, client: 192.168.1.12, server: myvideoimage.com, request:” GET / wp-admin / install. php HTTP / 1.1 “, upstream:” fastcgi: // unix: /var/php-nginx/159611529162207.sock/socket: “, host:” 192.168.1.13 ”
Do you have any idea about the problem and how to solve it?
I tried to insert the line: define (‘WP_CONTENT_DIR’, ABSPATH. ‘Wp-content’);
at the end of wp-config.php, but it doesn’t work.
Thank you very much.
