So I figured i could play around(Play being the key word) with Bind since I never had before, could’t be to hard. I mean no other service configurations ive played with were hard, within 30 minutes of looking at nginx i was doing all kinds of crazy pointless stuff.
I had 2 servers on, s1 and s2. I decided to setup 3, s3, to play around.
s1 and s3 run Webmin, s1 has webserver and other stuff including bind, s3 only runs bind.
s2 runs virturalmin.
I figured if i got it working I would do ns1 = s1 and ns2 = s3, so ns2 won’t be public.
I added s3 to s1’s Bind Cluster Slave Servers, set “Create secondary on slave when creating locally?” set to yes.
I found I can add zones and they get created as slaves on s3, dig seems to work correctly when connecting to s3 for the record.
Now when I was wondering how to get s2 to work with s1, i figures again, master/slave system.
I go in s2. add s1 to the Bind Cluster Slave Servers. I then create a host in virtualmin, Zone is created and a slave zone is made on s1. Save zone was not made on s3 though. I figure in this case I just have to make s3 a slave of s2.
Second, dig returns SERVFAIL when trying to dig the domain record from s1.
Anyways, heres some technical stuff:
root@s1:/etc/bind# named-checkconf -p
options {
directory "/var/cache/bind";
listen-on-v6 {
"any";
auth-nxdomain no;
allow-query {
"any";
zone "test.stormraidergames.com" {
type slave;
file "/var/lib/bind/test.stormraidergames.com.hosts";
masters {
99.198.122.62 ;
zone "s1.southstormhosting.com" {
type master;
file "/var/lib/bind/s1.southstormhosting.com.hosts";
also-notify {
99.198.122.17;
notify yes;
zone "." {
type hint;
file "/etc/bind/db.root";
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
server 69.175.32.250/32 {
root@s2:/etc/bind# named-checkconf -p
options {
listen-on-v6 {
"any";
auth-nxdomain no;
allow-query {
69.175.32.250/32;
99.198.122.172/32;
99.198.122.17/32;
allow-transfer {
69.175.32.250/32;
99.198.122.172/32;
99.198.122.17/32;
type master;
allow-transfer {
127.0.0.1/32;
"localnets";
zone "." {
type hint;
zone "localhost" {
type master;
type master;
type master;
type master;
dig(The first one is the server connecting to its self)
root@s1:/etc/bind# dig @s1.southstormhosting.com test.stormraidergames.com.
; <<>> DiG 9.7.0-P1 <<>> @s1.southstormhosting.com test.stormraidergames.com.
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 19646
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;test.stormraidergames.com. IN A
;; Query time: 0 msec
;; SERVER: 69.175.32.250#53(69.175.32.250)
;; WHEN: Tue Apr 26 23:19:28 2011
;; MSG SIZE rcvd: 43
root@s1:/etc/bind# dig @s2.southstormhosting.com test.stormraidergames.com.
; <<>> DiG 9.7.0-P1 <<>> @s2.southstormhosting.com test.stormraidergames.com.
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22045
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 0
;; ANSWER SECTION:
test.stormraidergames.com. 14400 IN A 99.198.122.62
;; AUTHORITY SECTION:
test.stormraidergames.com. 14400 IN NS s2.southstormhosting.com.
;; Query time: 1 msec
;; SERVER: 99.198.122.62#53(99.198.122.62)
;; WHEN: Tue Apr 26 23:21:06 2011
;; MSG SIZE rcvd: 94
