Will cloudmin run without bridge network?
I have a dedicated server with only one IP allocated to it and wanted to know if cloudmin will install and run on just that without having to create a bridge.
I have several kvm cloud servers with another data center and would like control them from cloudmin where I can create full backups of these kvm containers onto the dedicated server.
Is this possible?
Yes thats doable. Although you’d need cloudmin pro to control non local VMs. Pretty sure nothing other than a net connection is required since not all cloudmin instances control VMs, it controls physical machines also which would not require a bridge.
