Why does upgrading webmin modules through virtualmin often fail?
all the time or at least very often when upgrading webmin modules through the webinterface will fail. When I try to do an packages sync with upgrade again, it states I need to do a:
dpkg --configure -a
first.
Why is that? Anything I do wrong?
dsp
Its still the case:
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
Why does upgrade don’t run smoothly when triggered via virtualmin webinterface?
Dirk
Its still the case:
Dirk
Hey Dirk,
I’m not seeing this problem, though I am running into lots of dependency stupidity on my Debian development system (it’s kinda messy since I didn’t know much about Debian when I set it up).
Are there any other messages? I’ve never seen this particular error, and googling turns up nothing.
Its still the case:
Dirk
Hey Dirk,
Hi Joe,
do you upgrade virtualmin through virtualmin webinterface itself? It just stops with the output at a certain point… Trying to redo causes the message mentioned.
I then enter the shell do the command and everything is fine.
Dirk
