should not the code below use apt-get -y -f install php7.2-curl ? (instead of php72-curl)
PHP module curl is required …
Enabling module in PHP configuration …
… done
Installing package php72-curl …
Installing package(s) with command apt-get -y -f install php72-curl …
Reading package lists…
Building dependency tree…
Reading state information…
E: Unable to locate package php72-curl
… install failed!
If i go to webmin>system>software packages> then do a search through apt-get it has php7.2-curl
The same issues arises in this installation with php7.2-gd
Is a correction in the webmin package installer required to fill in the missing “.”?
