Hi guys,
i have finally got through the headache of getting blesta working on virtualmin.
- I am now wondering, which port do i assign during the Blesta Server configuration process for controling the server…my https port 443 or the virtualmin port 10000?
(my assumption is that i would need to use port 10000 but i am not sure)
i need to enter a server hostname for the virtualmin server intend to use blesta to provision services on. My assumption is that one should use hostname.fqdn? (ie “server1.mydomain.com” as blesta doesnt ask for an ip address for the server)
which user should ii setup to work with blesta? When using whmcs i think i was using the root user?
my admin user when logging into virtualmin itself, requires two factor authentication. Will this be a problem for blesta to interract with server in order to provision services?
