Which Linux OS is best for installing virtualmin pro
Hi all,
We want to install Virtualmin Pro in Azure VM or any other VPS.
Before starting just want to know which Linux operation system (OS) is most recommended, we don’t have any specific dependencies on OS.
This gets asked about once a month, and the answer is always the same:
Look at our Grade A supported OS list and pick the latest version of the OS you are most comfortable with. If you are not comfortable/familiar with any of them, pick one of the most popular ones (Rocky 9 or Ubuntu 22.04 LTS, right now).
Hi @Joe
Thanks for the information, I will be choosing ubuntu latest x version
Thank you
