I am getting a message every night when the cron job fires about the validation of the Dns server. i did try to fix the problem on my own by going to System/Recheck Virtualmin Settings and I follow the instructions and I add the address but it doesn’t seem to be hlding for some reason.
Here is the error message I get:
Virtualmin Validation Failed
Virtual server validation
Virtualmin configuration check
Virtualmin is configured to setup DNS zones, but this system is not setup to use itself as a DNS server. Either add 127.0.0.1 to the list
of DNS servers, or turn off the BIND feature on the module config page.Configuration errors found
What happens if I turn off the Bind function I am assuming that I won’t be able to use the VPS as a name server then?
