What happens if I loose my 2FA TOTP token for my admin account
I have not enabled 2FA yet because my webmin ports are hidden behind my NAT and that is where they will stay.
However if I enable 2FA on my main admin account and I loose my TOTP tokens, how can I login into Webmin again?
Lets also assume I do not have another system admin account or they are all locked because I lost the 2FA tokens for them as-well.
NB: I did look for 2FA docs and I could not find one so the solution added here would be helpful as a doc.
Will you have ssh access? You can disable in config file.
thats useful. so TOTP is only for the Webmin GUI.
Do you have any pointers where and what to make a change over SSH?
I want to add this to my notes before this issue happens.
Found it :slight_smile: (post from Ilia) That look like it reset to the systems root password.
You need to login as root using SSH and edit /etc/webmin/miniserv.users file, and replace:
root:x::::::::0:0:totp:HOQ7RXY76CGMOACH:
with
root:x:0
Note that root should correspond with your actual username. Also, don’t forget to restart Webmin after editing miniserv.users manually.
check this post
thanks, this will do nicely. I will add this to my notes.
