Recently I ran some Docker apps being reverse-proxied behind nginx and these apps use files and directories located in their /.well-known/ directory. However, the Virtualmin nginx snippet:
location ^~ /.well-known/ {
try_files $uri /;
was intercepting the port forwarding to the apps and I had to change it to make it more precise:
# do not intercept app /.well-known endpoint
# location ^~ /.well-known/ {
location ^~ /.well-known/acme-challenge/ {
try_files $uri /;
So as a feature request, would it be possible to use the more accurate
location ^~ /.well-known/acme-challenge/ ?
